update failing at 85%
753 1 2017-10-29
Haloweenhamster
hi i had an update for the mavic aircraft freeze at 85% using assistant 2 twice
first time i left it until the battery went flat, changed battery and it wouldnt connect to assistant 2 or controller
i sent it for repair and they wanted €475 because of a mark on the arm and body they said no longer covered by warrenty
so i brought a secondhand mavic went to update it and the same thing again 85% freeze, this time i left it just over 10 minuits, turned it off and let it cool, powered up and it still works
i used the blackbox feature in assistant 2 to get the update log which I'll attatch below
can you tell me cause of the failures please as i dont want to spend any more to be able yo fly
as you can see in the picture at the end of the log it says null over and over which didnt copy
10-25 17:47:51.478   244 11182 I DUSS&63[sys_p1_push_ongoing_stat:2989]:: Push to 0xa01 for module 0x801, overall upgrade progress: 85 (17:3:0), stop_pushing=0
10-25 17:47:51.478   244 11182 I DUSS&63[      sys_p1_upgrade_all:3631]:: upgrading p1 self, p1_first=1, p1_finish=0...
10-25 17:47:51.478   244 11182 I DUSS&63[sys_up_save_upgrade_stat: 369]:: fileName=/cache/upgrade_status, optionName=p1_first, optionValue=1
10-25 17:47:51.478   244   413 I DUSS&63[sys_up_status_push_threa: 992]:: +++++++ Sending upgrade status for upgrading_stage, len: 11, app_host=0xa01, mod_id=0x28 (08.01), status 1, progress: 0, total_progress: 85
10-25 17:47:51.567   244 11182 I DUSS&63[sys_up_save_upgrade_stat: 415]:: can not find this option, append new line
10-25 17:47:51.963   244   419 I DUSS&63[          sys_usb_switch: 323]:: mode: 0, up_status 4, conn_pc 1, conn_app_timeout 3, cam_rt_mode 0, cam_mode 5
10-25 17:47:52.115   244 11182 I DUSS&63[       sys_upgrade_p1_hw:3087]:: : Upgrading p1 hardware..
10-25 17:47:52.124   244 11182 I DUSS&63[         sys_p1_check_hw:2801]:: ver.Fw = 01.04.17.03
10-25 17:47:52.124   244 11182 I DUSS&63[         sys_p1_check_hw:2806]:: Targetr.Fw = 01.06.00.17
10-25 17:47:52.124   244 11182 I DUSS&63[       sys_check_version:  81]:: Different version.
10-25 17:47:52.124   244 11182 I DUSS&63[       sys_check_version:  82]:: Current ver.Fw = 1.4.17.3
10-25 17:47:52.124   244 11182 I DUSS&63[       sys_check_version:  87]:: Targetr.Fw = 1.6.0.17
10-25 17:47:52.147   244 11182 I DUSS&63[       sys_upgrade_p1_hw:3235]:: Set p1_upgrade state to 1
10-25 17:47:52.156   244 11182 I DUSS&63[sys_up_get_flag_from_fil: 140]:: cat results: 2
10-25 17:47:52.226   244 11182 I DUSS&63[sys_p1_send_ota_power_st: 686]:: Send ota power down message to 0xa01
10-25 17:47:53.248   244 11182 I DUSS&63[       sys_upgrade_p1_hw:3269]:: will reboot recovery soon...
!!!new file start!!!
01-01 00:02:47.647   242   242 I DUSS&63[                    main: 639]:: dji_sys run as dev_type 0, duss_sketch_initialize done...
01-01 00:02:47.656   242   242 I DUSS&63[sys_load_config_from_jso: 154]:: Get the hw_str WM220 AC
01-01 00:02:47.656   242   242 I DUSS&63[         sys_load_config: 473]:: platform dev_info: WM220 1860AC
01-01 00:02:47.719   242   242 I DUSS&63[sys_check_boot_mode_norm: 321]:: Set system mode to NORMAL.
01-01 00:02:47.783   242   242 I DUSS&63[sys_up_load_general_stat: 198]:: get option_value wm220 for package_id
01-01 00:02:47.783   242   242 I DUSS&63[sys_up_load_general_stat: 199]:: updated package_str wm220
01-01 00:02:47.783   242   242 I DUSS&63[sys_up_load_general_stat: 206]:: get package_ver 1.4.0
01-01 00:02:47.783   242   242 I DUSS&63[sys_up_load_general_stat: 210]:: updated package_ver 1.4.0
01-01 00:02:47.783   242   242 I DUSS&63[sys_up_load_general_stat: 217]:: get package_uav_cnt 17
01-01 00:02:47.783   242   242 I DUSS&63[sys_up_load_general_stat: 219]:: updated package_uav_cnt 17
01-01 00:02:47.783   242   242 I DUSS&63[sys_up_load_general_stat: 226]:: get package_gnd_cnt 0
01-01 00:02:47.783   242   242 I DUSS&63[sys_up_load_general_stat: 228]:: updated package_gnd_cnt 0
01-01 00:02:47.783   242   242 I DUSS&63[sys_up_load_general_stat: 235]:: get package_gls_cnt 0
01-01 00:02:47.783   242   242 I DUSS&63[sys_up_load_general_stat: 237]:: updated package_gls_cnt 0
01-01 00:02:47.783   242   242 I DUSS&63[sys_up_load_upgrade_stat: 270]:: file /cache/upgrade_status not exist, return directly
01-01 00:02:47.798   242   242 I DUSS&63[sys_upgrade_check_status:4766]:: didn't save upgrade_retry in last boot
01-01 00:02:47.798   242   242 I DUSS&63[sys_upgrade_check_status:4791]:: non need to push upgrade status, set upgrade status to idle.
01-01 00:02:48.092   242   242 I DUSS&63[            sys_pre_init: 519]:: this is production board
01-01 00:02:48.105   242   242 I DUSS&63[      wl_prot_tcp_create: 404]:: [sys]open_type=1, local_port=22350, remote_ip=0.0.0.0, remote_port=0, l_ctx=0xb71351f8
01-01 00:02:48.106   242   242 I DUSS&63[      wl_prot_tcp_create: 452]:: [sys]create tcp listen task success, task=0xb7135258
01-01 00:02:48.107   242   242 I DUSS&63[      wl_prot_tcp_create: 500]:: [sys]create tcp channel success, l_ctx=0xb71351f8
01-01 00:02:48.295   242   242 I DUSS&63[        sys_events_start:  96]:: aging_test_mode=0, system_mode=0
01-01 00:02:48.296   242   242 I DUSS&63[            sys_ltc_init: 637]:: use the same i2c device /dev/i2c-1 for version read
01-01 00:02:48.296   242   242 I DUSS&63[            sys_ltc_init: 641]:: check the cpld version and toggle program pin.
01-01 00:02:48.297   242   242 I DUSS&63[   sys_ltc_program_check: 536]:: return ver 0x406
01-01 00:02:48.298   242   242 I DUSS&63[       sys_check_pc_conn: 292]:: pc state is CONFIGURED
01-01 00:02:48.298   242   242 I DUSS&63[           sys_post_init: 547]:: conn_pc=1 when init
01-01 00:02:48.299   242   242 I DUSS&63[      sys_usbclient_init: 496]:: MFi: Ignore mobile channels...
01-01 00:02:48.300   242   394 I DUSS&63[sys_up_status_push_threa: 764]:: pushing thread start, stop_pushing=1
01-01 00:02:48.316   242   242 I DUSS&63[sys_uevent_force_usb_eve: 626]:: ttyACM0 modalias: usb:vFFF0p0008d0100dc02dsc00dp00ic02isc02ip00in00
01-01 00:02:48.317   242   242 I DUSS&63[sys_uevent_force_usb_eve: 635]:: ttyACM0: force trigger add uevent /sys/class/tty/ttyACM0/uevent!
01-01 00:02:48.326   242   242 I DUSS&63[sys_uevent_force_usb_eve: 657]:: force trigger add uevent /sys/class/net/usb0/uevent
01-01 00:02:48.422   242   398 I DUSS&63[ handle_dji_device_event: 350]:: ttyACM0 modalias: usb:vFFF0p0008d0100dc02dsc00dp00ic02isc02ip00in00
01-01 00:02:49.326   242   242 I DUSS&63[    sys_p1_up_check_conn:3854]:: check connection with camera failed: -1002
01-01 00:02:49.777   242   372 I DUSS&63[        sys_event_reboot:1353]:: receive reboot from 0xb00, this_host=0x801
01-01 00:02:49.777   242   372 I DUSS&63[        sys_event_reboot:1359]:: Get reboot callback. .
01-01 00:02:49.777   242   372 I DUSS&63[           sys_p1_reboot:4526]:: Request power/boot 2 after 0 ms from 0xb00
01-01 00:02:49.777   242   372 I DUSS&63[  sys_notify_reboot_peer:4501]:: power: send command 104, -1001
01-01 00:02:49.777   242   372 E DUSS&63[  sys_notify_reboot_peer:4503]:: power: can not reach peer, result=-1001, retry_count=0
01-01 00:02:49.777   242   372 I DUSS&63[  sys_notify_reboot_peer:4501]:: power: send command 72, -1001
01-01 00:02:49.777   242   372 E DUSS&63[  sys_notify_reboot_peer:4503]:: power: can not reach peer, result=-1001, retry_count=1
01-01 00:02:49.777   242   372 I DUSS&63[  sys_notify_reboot_peer:4501]:: power: send command 66, -1001
01-01 00:02:49.777   242   372 E DUSS&63[  sys_notify_reboot_peer:4503]:: power: can not reach peer, result=-1001, retry_count=2
01-01 00:02:49.777   242   372 I DUSS&63[  sys_notify_reboot_peer:4501]:: power: send command 68, -1001
01-01 00:02:49.777   242   372 E DUSS&63[  sys_notify_reboot_peer:4503]:: power: can not reach peer, result=-1001, retry_count=3
01-01 00:02:49.777   242   372 I DUSS&63[  sys_notify_reboot_peer:4501]:: power: send command 60, -1001
01-01 00:02:49.777   242   372 E DUSS&63[  sys_notify_reboot_peer:4503]:: power: can not reach peer, result=-1001, retry_count=4
01-01 00:02:49.777   242   372 E DUSS&63[       sys_notify_reboot:4465]:: duss_event_send() power error: -1001
01-01 00:02:49.777   242   372 E DUSS&63[       sys_notify_reboot:4465]:: duss_event_send() power error: -1007
01-01 00:02:49.832   242   372 I DUSS&63[           sys_p1_reboot:4597]:: response to reboot msg fail, result=-1007
01-01 00:02:49.832   242   372 I DUSS&63[           sys_p1_reboot:4603]:: going to reboot/poweroff/powersave... reboot_type 2 reboot_mode 0
01-01 00:02:59.702   230   230 I DUSS&63[                    main: 639]:: dji_sys run as dev_type 0, duss_sketch_initialize done...
01-01 00:02:59.708   230   230 I DUSS&63[sys_load_config_from_jso: 154]:: Get the hw_str WM220 AC
01-01 00:02:59.709   230   230 I DUSS&63[         sys_load_config: 473]:: platform dev_info: WM220 1860AC
01-01 00:02:59.750   230   230 I DUSS&63[sys_check_boot_mode_norm: 321]:: Set system mode to NORMAL.
01-01 00:02:59.858   230   230 I DUSS&63[sys_up_load_general_stat: 198]:: get option_value wm220 for package_id
01-01 00:02:59.858   230   230 I DUSS&63[sys_up_load_general_stat: 199]:: updated package_str wm220
01-01 00:02:59.858   230   230 I DUSS&63[sys_up_load_general_stat: 206]:: get package_ver 1.4.0
01-01 00:02:59.858   230   230 I DUSS&63[sys_up_load_general_stat: 210]:: updated package_ver 1.4.0
01-01 00:02:59.858   230   230 I DUSS&63[sys_up_load_general_stat: 217]:: get package_uav_cnt 17
01-01 00:02:59.858   230   230 I DUSS&63[sys_up_load_general_stat: 219]:: updated package_uav_cnt 17
01-01 00:02:59.858   230   230 I DUSS&63[sys_up_load_general_stat: 226]:: get package_gnd_cnt 0
01-01 00:02:59.858   230   230 I DUSS&63[sys_up_load_general_stat: 228]:: updated package_gnd_cnt 0
01-01 00:02:59.858   230   230 I DUSS&63[sys_up_load_general_stat: 235]:: get package_gls_cnt 0
01-01 00:02:59.858   230   230 I DUSS&63[sys_up_load_general_stat: 237]:: updated package_gls_cnt 0
01-01 00:02:59.858   230   230 I DUSS&63[sys_up_load_upgrade_stat: 270]:: file /cache/upgrade_status not exist, return directly
01-01 00:02:59.875   230   230 I DUSS&63[sys_upgrade_check_status:4766]:: didn't save upgrade_retry in last boot
01-01 00:02:59.875   230   230 I DUSS&63[sys_upgrade_check_status:4791]:: non need to push upgrade status, set upgrade status to idle.
01-01 00:03:00.041   230   230 I DUSS&63[            sys_pre_init: 519]:: this is production board
01-01 00:03:00.053   230   230 I DUSS&63[      wl_prot_tcp_create: 404]:: [sys]open_type=1, local_port=22350, remote_ip=0.0.0.0, remote_port=0, l_ctx=0xb7141248
01-01 00:03:00.053   230   230 I DUSS&63[      wl_prot_tcp_create: 452]:: [sys]create tcp listen task success, task=0xb71412a8
01-01 00:03:00.053   230   230 I DUSS&63[      wl_prot_tcp_create: 500]:: [sys]create tcp channel success, l_ctx=0xb7141248
01-01 00:03:00.156   230   230 I DUSS&63[        sys_events_start:  96]:: aging_test_mode=0, system_mode=0
01-01 00:03:00.158   230   230 I DUSS&63[            sys_ltc_init: 637]:: use the same i2c device /dev/i2c-1 for version read
01-01 00:03:00.158   230   230 I DUSS&63[            sys_ltc_init: 641]:: check the cpld version and toggle program pin.
01-01 00:03:00.159   230   230 I DUSS&63[   sys_ltc_program_check: 536]:: return ver 0x406
01-01 00:03:00.160   230   230 I DUSS&63[       sys_check_pc_conn: 292]:: pc state is CONFIGURED
01-01 00:03:00.161   230   230 I DUSS&63[           sys_post_init: 547]:: conn_pc=1 when init
01-01 00:03:00.161   230   230 I DUSS&63[      sys_usbclient_init: 496]:: MFi: Ignore mobile channels...
01-01 00:03:00.167   230   387 I DUSS&63[sys_up_status_push_threa: 764]:: pushing thread start, stop_pushing=1
01-01 00:03:00.169   230   230 I DUSS&63[sys_uevent_force_usb_eve: 626]:: ttyACM0 modalias: usb:vFFF0p0008d0100dc02dsc00dp00ic02isc02ip00in00
01-01 00:03:00.169   230   230 I DUSS&63[sys_uevent_force_usb_eve: 635]:: ttyACM0: force trigger add uevent /sys/class/tty/ttyACM0/uevent!
01-01 00:03:00.180   230   230 I DUSS&63[sys_uevent_force_usb_eve: 657]:: force trigger add uevent /sys/class/net/usb0/uevent
2017-10-29
DJI Thor
Flight distance : 13602 ft
Is there an error code at last? Could you please provide me with the screenshot of DJI Assistant 2 when it gets stuck? I would like to check first.
Besides, it would be nice if you could upload the upgrade log to Dropbox so I can grab the original text for checking. Here's the route: Window:C:\Users\xxx\AppData\roaming\DJI assistant2\upgrade_log
2017-10-29
