dji mavic pro battery problem two middle lights stay on.
10891 9 2017-10-29
Tutay
New Zealand
good day please help the two lights on my mavic battery stays on and the battery stays on. before this thing happen the app says update then I update but the update was unsuccessful due to the wifi suddenly disconnected but when I try to update it again it doesn't allow me to do it and that s__t happen. does anyone know how to fix this problem? please help thank you.
2017-10-29
DRONE-flies-YOU
Flight distance : 1450594 ft
Plug the R/C into the computer via USB. Turn it & the Mavic on. Update via DJI Assistant 2. Or do a "refresh" of the firmware if it doesn't say update.  Next time, ONLY update your Mavic this way or you run that risk.
2017-10-29
DJI Thor
Flight distance : 13602 ft
This means that the battery upgrades failed and you need to upgrade the battery again. To fix this issue, upgrade the battery firmware again. Please remove the battery and try to charge it for about 2 hours, and then mount the battery to the aircraft, connect your drone to the computer and try to upgrade it via DJI Assistant 2 again. The middle 2 LED lights will keep lighting and the power button of the battery will not work until the upgrade is successful.
2017-10-29
DRONE-flies-YOU
DJI Thor Posted at 2017-10-29 18:28
https://www.youtube.com/watch?v=HZE-fP28htI&list=PL8-vxWY64sBNLusG0MvxD4Dm-tX4cnvzX&index=9
What you suggested has been proven not to work. I've had this issue AND HAD TO FIGURE THIS OUT MYSELF!
2017-10-29
DJ Enertia
Flight distance : 614065 ft
DRONE-flies-YOU Posted at 2017-10-29 18:31
When i last updated all went well untill i updated my 5th battery same thing happened.i unpluged battery from mavic waited minute then i restared Assistant2 then repluged in blinking battery in mavic thats already had usb pluged in pc,select mavic in assistant2 then when promted to update update it again and dont worrie the battery will keep blinking untill update over and mavic automaticly reboots and battery blinking should stop if all goes well as it did for me.
2017-10-30
DJI Thor
What'd you got when you re-updated the firmware? If my suggestion didn't help, would you mind telling me when did you purchase the battery? I suggest sending it in if it is under warranty period.
2017-10-30
fans5aee5495
Flight distance : 3772247 ft
DJI Thor Posted at 2017-10-30 22:47
I had this problem and resolved it this way. Charge the battery to full, the twoled  lights will remain during this, if you use the Mavic multicharger then the charger light will go green, then its fully charged. Delete all files on the Mavic microsd card. Use assistant with the two led lite battery in the Mavic to update the Mavic firmware. Worked for me. Good luck.
2017-10-31
fans5aee5495
2017-10-31
DJI Thor
fans5aee5495 Posted at 2017-10-31 15:16
Good try. And glad to hear your work solved the problem. Thank you for posting.
2017-11-1
Tutay
New Zealand
thank you guys already fix it.
2017-11-1
