Drone Maintenance Checklist
12Next >
39800 66 2017-10-30
DJI Grace
China
The following information origins from DJI Buying Guide
Need some guidance for checking up your drone, maintaining battery health, transporting your drone properly etc.? This checklist can help you maintain your drone and avoid unnecessary failures as drone maintenance is key to your flight safety.
Visual Inspection
  • Inspect the outer shell and other components for damage. Contact DJI Support if any damage is spotted. Do not modify the structure of DJI products.Only use original or certified DJI accessories.
  • Check condition of propellers before and after every flight. Make sure there are no bent blades or cracks.
  • Inspect the gimbal for damage and camera lens for dust or dirt.
Battery
  • Read theIntelligent Flight Battery Safety Guidelines.
  • Use a fully charged battery. If a battery is idle for a long time, its performance might be affected.
  • Do not allow the battery to come into contact with liquids. This will lead to permanent damage.
  • Don’t remove or install the battery from the aircraft when it’s turned on.
  • Check the status of the battery in the DJI GO app after powering on the aircraft. Keep an eye out for app alerts during flight. If the DJI GO app displays a warning that battery cells are abnormal or damaged, stop using the battery.
  • Follow the stated temperature for battery use.
  • Don’t charge the battery right after a flight because the battery’s temperature may be too high. Avoid charging the battery outside of the stated charging temperature range.
  • After charging is complete, disconnect the battery from the charger.
  • Examine the charger regularly for damage to the cord , plug, enclosure or other parts. Never use a damaged charger.
  • Fully charge and discharge the battery once every three months to maintain battery health.
  • Pre-heat your battery to 20°C(68°F) when the temperature is lower than 10°C(50°F). It is recommended to use a DJI Intelligent Battery Heater. The DJI Intelligent Flight Battery Heateris only supported on the Phantom 3 series and Inspire 1 series Intelligent Flight Batteries. The Inspire 2 Intelligent Flight Battery features auto heating.
  • If you fly in high temperatures above 40°C(104°F), keep an eye on battery temperature. If the battery’s temperature get higher than 65°C(149°F), land your drone immediately.
    Transportation
  • Store the battery in a specified transportation box/bag before the transit to avoid damage from external forces. Do not store a battery with metal components.
  • Remove batteries from the aircraft when stored for an extended period.
  • Discharge the battery to 30% before transit. If the battery needs to be carried onto the plane, discharge it to 5% of its total power.You can set your batteries to self-discharge in DJI GO app.
  • Attach the gimbal clamp when storing your drone. This will effectively help to avoid any damage to your gimbal.
  • If you transport your drone a long way, it’s a good idea to re-calibrate your compass before flying again.
  • Remove your propellers when you transport your drone(it’s not necessary for Spark).
    Storage
  • Store the aircraft in a dry, cool and non-magnetic place to avoid any damage.
  • When the aircraft and the battery will be stored for more than 3 months, store in around 25°C(77°F) and avoid direct sunlight.
  • Discharge the battery to 40% to 65% prior to storage. Storing a battery with full power or low power for a long time may lead to permanent damage.
Follow these tips will help you properly maintain your drone. If you find this helpful, please share this article with other drone pilots.
Happy flying!
Learn more!
2017-10-30
DJI Grace
China
hey guys~~~
You can go to https://store.dji.com/guides to find more useful and amazing tips~
Any questions about this are freely to discuss here
2017-10-30
DJI Grace
China
hey, guys, really pleasant to see the information would help. Later on, we will share more and just keep up with us!
2017-11-2
DJI Grace
China
will be more and more ~
2017-11-3
A CW
Flight distance : 11526437 ft
Really thorough advice - thanks for posting!
2017-10-30
jcaerialstudio
Flight distance : 171040 ft
Thank you for an awesome tip!
2017-10-30
F.KOK
Flight distance : 11970495 ft
Namibia
Thanks for this.
2017-10-30
Strudy
Flight distance : 36119 ft
Very informative thank you
2017-10-30
Jessica.X
China
Useful tips! Thanks~
2017-10-30
ro_flyer
Flight distance : 4784701 ft
Brazil
Thanks for this checklist!
2017-10-30
Woe
Flight distance : 3423337 ft
Thanks for the great info.
2017-11-1
Zippo43
Flight distance : 318317 ft
Now.......how about a nice short article  that helps us to clean that tiny bare lens on the drones cameras....i pretty much know as a photographer  But   many don't know so  a nice message on  Camera lens care would be great !......Thank You  Dji
2017-11-1
fans30dc1bbe
Argentina
In spanish please
2017-11-1
MBrown
Flight distance : 619787 ft
Thanks for the Tips.
2017-11-1
Ryan's Sparky
Flight distance : 302316 ft
Norway
top tips thanks
2017-11-2
Super Dodoz
Flight distance : 118422 ft
Great info. Thanks for sharing
2017-11-2
DJ Enertia
Flight distance : 614065 ft
thanks for sharing
2017-11-2
JamesWhenman
Flight distance : 426375 ft
Good info, Thanks !
2017-11-3
Commander4
Flight distance : 578094 ft
Excellent.......
Thank-you for the information very useful for the safe operation of U.A.V.
Don't forget to check the Transmitter Battery / Control sicks / Antennas
Please forgive me if I missed something............
2017-11-4
CraigVG
Flight distance : 18547 ft
Good info for us newbies.  Thanks!
2017-11-10
M.C. Pilot
Flight distance : 8277736 ft
superb tips ! thanks !
2017-11-10
djiuser_IUbj4lU
Flight distance : 295925 ft
Great tips
2017-11-11
zl1_ghost
Flight distance : 410430 ft
Thanks.  This is good advice for a new owner.
2017-11-27
DJI Grace
China
zl1_ghost Posted at 2017-11-27 04:29
Thank you for your comment!
2017-11-27
Biensky
Flight distance : 650991 ft
Philippines
Very helpful, thank you so much
2017-11-28
DJI Grace
China
Biensky Posted at 2017-11-28 21:06
You are welcome!
2017-11-28
Cole1
Hi DJI Grace
2017-12-2
Cole1
Thank you for all the intel I have just raised a query in general about maintenance please be gentle and to the point.
2017-12-2
MichaelaKinberg
Flight distance : 28301 ft
Austria
Hi,
what's the easiest fastest way to discharge my Sparks battery. Can't find itDJI GO app. At the moment I fly the spark outdoors, but when it get's colder I can't fly it indoors to discharge the battery
Thanks for your help.
Michaela
2017-12-8
Nebuchadnezzar
Flight distance : 1662562 ft
Thanks for share !!
2017-12-12
Mavin
Flight distance : 36611 ft
United Arab Emirates
Has anyone found a source for the cellophane bags some airlines want Lithium battery packed in?
2017-12-15
Realitybytes
Flight distance : 69724 ft
VG, I didnt know that you can set your batteries to self-discharge in DJI GO app, thanks
2018-1-15
InJamaica
Flight distance : 799701 ft
Jamaica
Thanks for this
2018-1-22
Mini-G
Flight distance : 145246 ft
Hi, is there a flight temperature range for the Mavic Pro?
2018-1-26
fans359e3687
Flight distance : 26024 ft
Hello I need some help
2018-2-8
DJI Grace
China
hey, how can I help there?
2018-2-8
dwainwayne28
Flight distance : 583323 ft
Trinidad and Tobago
Thanks for sharing this info..Very useful indeed !
2018-2-15
Dorset_Horn
Flight distance : 57254 ft
Some helpful tips on batteries. Thanks.
2018-2-19
Sam Saini
New Zealand
Hi...i bought Mavic Air couple of weeks ago ....first flight was perfect and when i fly second time after 5 days, it starts smells burning and immediately i took the battery off and i took back to DJI authorized seller from where i bought this drone. They kept the drone for few days and returned me back and said there is no fault with this drone, but drone still smells weird like something heat up and melted inside, i explained them what happened and this was happened in first week, drone should be replaced, i found this is not a good service provided by DJI. Is any thing i can do to fix this.
Thanks
Sam
2018-2-25
Guido-Italy
Flight distance : 471453 ft
thank you for details
2018-4-17
12Next >
