Drone Maintenance Checklist
12
38431 66 2017-10-30
VigilanteDrones
Flight distance : 3819505 ft
Any chance DJI will ever come out with tool/maintenance kits specific to their drones?
2018-5-1
DJI Grace
VigilanteDrones Posted at 2018-5-1 22:14
Your constructive suggestion have already transferred to the product team! Thank you for your advice
2018-5-1
VigilanteDrones
DJI Grace Posted at 2018-5-1 22:43
Thanks Grace!
2018-5-2
X-Fighter
Brazil
Great post! Thank you! There's something about how to cleaning/drying motors?
2018-5-8
TechVoyager
Flight distance : 59993 ft
India
Sam Saini Posted at 2018-2-25 05:01
Hi...i bought Mavic Air couple of weeks ago ....first flight was perfect and when i fly second time after 5 days, it starts smells burning and immediately i took the battery off and i took back to DJI authorized seller from where i bought this drone. They kept the drone for few days and returned me back and said there is no fault with this drone, but drone still smells weird like something heat up and melted inside, i explained them what happened and this was happened in first week, drone should be replaced, i found this is not a good service provided by DJI. Is any thing i can do to fix this.
Thanks
Sam
Its normal Sam Saini. As the  board, motors and the batteries are new so there will be little burn-in in new drones. It will eventually go away after couple of flights. Hope that helps
2018-5-14
jimfalt
Flight distance : 33474 ft
thanks for sharing
2018-5-14
DMX_MT
Malta
Thanks for all this Info Dear DJI Grace !
2018-7-4
dronto
Singapore
wow thanks Grace for the useful guides
2018-7-18
GnarlyGuy
Flight distance : 242421 ft
Malaysia
Thanks for posting.
2018-7-25
TimDerLauch
Thanks for sharing !
2018-8-8
elkabubi
Flight distance : 467703 ft
I was looking for something like this, on the down side... it will be an additional kit to buy and raises the investment required while flying.
however if you use to take care of them as I did. you will do it anyway. so the advantage is that you could get everything from the same place and from the manufacturer.
I would also suggest that if with this or other way. can be proven that the drone has been undergoing preventive maintenance maybe the waranty could be extended??
like in the cars. every XXX amount of Km you should give some service to it?
The moment I reached flight 100 I remember I was thinking on... (It has been allready lots of Flights... when should I first do its preventive maintenance)?
2018-8-31
rolling56
Flight distance : 138310 ft
Use Google Chrome and the translate feature
2018-10-25
Fre Mo
Flight distance : 529803 ft
Just read the battery instructions:  « Charge and discharge the battery completely once every 20 charge/discharge cycles. Discharge the battery until there is 0% of power or until it can no longer be turned on, then recharge it to the maximum capacity. This power cycling procedure will optimize the battery life. »
How are we supposed to fully discharge the battery?
2018-12-15
Joszhe Tosa
Good thread. Thanks for the information.
2018-12-21
Fre Mo
Fre Mo Posted at 12-15 00:14
Any idea to discharge the battery quickly, my drone does not take off below 10% battery.
2018-12-23
Fre Mo
Is it normal that the cells are not balanced when fully discharging the battery?
2018-12-23
CharlieZ
Flight distance : 269137 ft
Good to know, thanks!!
1-5 17:06
darkfull1
Flight distance : 13114 ft
Switzerland
Great list but I see that the gimbal needs to be protected when carrying the drone. Why isn't there a gimbal cover for the spark in the fly more combo or even with the drone when it's purchased?  Of course I bought one (Even 2 by accident) but many people might not be able to purchase one where they are and might need it.
1-11 15:40
Sayhelloforme
Flight distance : 8133219 ft
Great information. Thanks for sharing.
1-12 17:14
Hogtopia
Flight distance : 2723 ft
I have a new to me Inspire 2 that I purchased from the original order.  One of the first things I did was to make sure the memory cards were empty and so I dumped their content to my local computer and then emptied the contents.  When putting the SD Card back in, I keep getting an Error that says, The SD card has an error, please replace it."  The card works in my GoPro Hero 7 .  Its a SanDisk Extreme 128GB U3 which I believe is compatible.  I've also tried a second one of these cards and get the same error.  The cards work fine in other media devices and the computer.  I'm not really sure what to do next.   The last thing I did was try formatting it on the system after resetting the camera and most of the time it says the card is no good, but on a few occasions it starts to format it but never ends.
Thoughts on next steps ?
1-24 18:39
cutis
Flight distance : 1007756 ft
Hogtopia Posted at 1-24 18:39
Be careful mating to energized host OS pc. Connect when all power dead, then ascend power, right? DON'T PLUG PLAY ENERGIZED.
Understand craft is not assigned earth like pc smps dc powering.
Transients can be felt by sdcard being highly voltage spike vulnerable to puncturing irreversibilities. Sdcards are not robustful like thumb drive jumpdrive tolerant
2-19 13:16
BKBear
Flight distance : 67697 ft
Great tip on batteries, just found this looking through the forum.
4-1 17:12
MRomine
Flight distance : 190102 ft
"If the battery needs to be carried onto the plane, discharge it to 5% of its total power.You can set your batteries to self-discharge in DJI GO app."
Where is the self-discharge option found in the DJI Go4 app? Is the location different is using the Smart Controller?
5-15 16:15
usere02be016f0
I have a Phantom 3 professional 4K and when i turn the controller on it continuously beeps with a red LED light. When i connect the RC to the DJI Go app it’s says battery low.
When i try and charge the RC it stays charging for maybe a few minutes and turns off. Basically not holding a charge.
I’ve also tried recalibrating the RC and still have no luck.
5-31 07:44
Cam9292
Flight distance : 22598 ft
Absolutely some good tips and habits to form!
7-1 06:10
Miro Perez
Flight distance : 25374 ft
Thanks for the advice
8-28 15:21
fans6886861f
Flight distance : 308350 ft
hello i buy a camera zemmus x3 for inspire 1 i just plug it in for the first time and it does not light it turns not on itself how can i check what recieves properly energy.
9-6 06:21
12
