jcgoobee
Flight distance : 476119 ft
I was flying my Spark the past weekend and wanted to test its claimed maximum altitude that it can reach.
Everything went smoothly and the video feed was great, up until it reached around 1,100 feet which was around the cloud level, the Spark started to report really odd altitude readings, flickering between 0 feet to 900+ feet, then normalized until I went up to a bit shy of 1,300 feet, then the DJI Go 4 app showed "disconnected".
After more than 70 flys, I told myself not to panic, and just hit the RTH button since the RC still shows green. I heard the audible beep but waited for a few minutes, yet found no sign of my Spark. I started to think, what I could do to bring the Spark back as I was getting really worried. I disregarded my RC's RTH, and started dropping the stick to descend, at least for about 3 minutes, which felt eternity. Thank goodness I finally saw my Spark to show up, and the battery level has reached to extremely low level and must land. I manually landed my Spark and found a very little battery left. Good thing was, it did not crash and I managed to land it successfully. I looked at the Spark, and found some water spot all over probably due to entering and exiting the cloud and the moisture hit the body. I wonder if this could contribute the failure to read the altitude correctly, as well as causing the RTH to fail.
I further confirmed that the RTH failed multiple times when I looked at the flight replay from the DJI 4 go app. Unfortunately, it did not tell me why it failed.
Has anyone experienced this and how to tackle this problem? What would you do in my situation? Thanks.
James
