Edd_88
When I take 9 frame, I srart with point the cam to POI (say the gimbal at -40 degree) then commence the sequence, the first photo will be the same as I point to then up, down, left right and the resulting photo came out as I expect, the POI in the center. However, AC in sam position and cam point at the same POI (-40 degree), once commence the 21 frame sequence, the gimbal move stright up to horizon the take the first photo the up (can see the props and sky), down left right left right up down as needed. At the end, the POI was out of the frame (not even covered in the lowest frames. Is it how the Spark 180 should do? There is no point to take a shot that the POI is not imcluded! |
