From what I read on the DJI site the Sony is too big for the Ronin, but I did find a video that shows the sony hooked up to the Ronin. It's unclear if the guy who made the video modified the Ronin to do that or if it works properly.
Does anybody know for a fact that the sony won't fit on the Ronin?
Thanks
P.
Camera size requirement: the maximum depth from the center of gravity on the camera base plate is 140mm; the maximum height measured from the top of the camera base plate is 225mm; and the maximum width is 195mm.you may check.
And the recommend camera weight is less than 7.25kg, please double check the specs of your camera
