Kidologist
Flight distance : 4415722 ft
This is a helpful, but confusing thread. I almost wish I hadn’t bought the Goggles until I get a Mavic, with Spark it is a PAIN, but here is what I have learned since my last post above.
There are TWO methods you can use. Each has pros and cons, and both should be fixed by DJI.
Option 1: Fly with Goggles connectedvia OTC directly to RC. DOWNSIDES: No Plan B if something goes wrong, you have to dirch goggles and fly back manually with eyes] sight, if you dont see drone, ops, and no map placement to find it. Plus, no log or experience points in app for those who enjoy that, since the dji app isn”t used.
But!!! For it to work, you must FIRST connect with app, be logged in and take off. THEN switch to Goggles. (This is described above), otherwise your range will be limited as you are considered an unidentified operator. Its a pain and you waste some battery life.
Option 2: Fly HDMI. This enables ypu to get log and points, have mobile device as backup, you can flip up the goggles and switch to mobile devoce control, which you likey re more comfortable with. If anything goes wrong, you”ll have your map and return to home as usual. Downside is that the display tends to flicker a bit as there are dual displays, and the goggles mirror your mobile devoce, so its not as large or as immersive.
Both work - with option 1 the experience is better visually but more stressful. Option 2 is a little clunky visually, but I‘ve found it better overall, and likely safer too. Keep in mind you cant use the OTC with your device because you need the mobile port for the goggles for HDMI, and splitters have not worked in my testing.
Hope this helps. With both methods, you cant |
