P3A Gimbal Status 'Disconnected' but seems to work
1467 5 2017-11-1
robinby04
New Zealand
Hi guys,
I hadn't flown my P3A for quite some time, and last weekend decided to take it out for a spin. When I did this, I noticed my live feed was very delayed.
I researched how to fix this, and I found that if I took the whole camera/gimbal off the drone, disconnecting the 2 wires, and then connecting them back again, it should fix my issue.
I did this, and it seems to have worked, my live feed is back to normal. BUT when i go into the aircraft status in the DJI GO app, at the bottom, the Gimbal Status says 'Disconnected'.
I don't know if this was an issue before disconnecting the camera/gimbal or if it happened when I did the fix, but I can't get it to go away.
Everything seems to work, the gimbal is in the usual position, all lights are green, there are no warning messages, when I fly the drone the camera works just as normal and I can move the camera up and down as usual. I can even calibrate the gimbal, but the gimbal status still says Disconnected...
Any help on the matter? Should I be worried, should I just fly it regardless?
Thanks.
2017-11-1
Mxh666
Flight distance : 46371 ft
Here is a link on the Phantom Pilots Forum with same same issue.
Looks like it is a software bug. I have the same message, but the drone flies normal and everything else is ok.
https://phantompilots.com/thread ... 25462/#post-1281587
2017-11-1
DJI Diana
Flight distance : 2408 ft
We are aware of this issue, this is a false warning, the engineers are working on it now, will fix it in the next update.
2017-11-1
elmt136-sp
Flight distance : 7946 ft
I have the same problem the status in my phantom 3 said gimbal disconnect. that happen after did the last  update. so how long we have to wait for to fix this problem?
2017-11-3
Air/America
My P3A says the same, "Gimbal Status Disconnected". Other than that message, everything appears to function normally.
2017-12-29
Air/America
Air/America Posted at 2017-12-29 13:04
The current DJI GO 3.1.23 has corrected the "gimbal status disconnected" error message.
2017-12-29
