Mark The Droner
Flight distance : 2917 ft
Reynardi Posted at 2017-11-2 20:23
Hi, why my Phantom 3 SE can not hover in the same place? it's always going to right or left, forward and backward
S1 = P mode, S2 in the middle position, GPS Signal 7
This is a P3S thread which uses straight GPS. The P3 SE uses GPS/Glonass. Moving around a little is normal, especially if you're not using VPS. Variance is + - 1.5 meters. Also, I don't know if 7 satellites is enough. Also, I don't know why you'd only get 7 unless you were in a canyon or something. |
