AEM74
Flight distance : 332677 ft
AG0N-Gary Posted at 2017-11-3 10:51
Let's see... I'm running low on battery. Maybe I should go to Sport mode and use even more power to try to outrun the battery drainage. Doesn't make sense to me. Batteries typically go down faster when used harder, and I don't mean just because you're using more power. Just like your gas gauge goes down faster when you drive faster. It will normally not go the same distance when used hard as it would if being used conservative. Of course, if you're fighting a head wind, you've got to compromise and choose a speed that will get you further, without depleting the battery faster than necessary. Your flights should always be arranged so that you are heading home with a tailwind when possible. I try to always get home with 20% or so remaining.
Well in the end, the drone came back in a minute and I had 21% of my battery left. If I would have ran below that, I had plenty of area to safely land my drone and retrieve it later on. It's obvious that when I hit the 30% warning level that maybe using sport mode might not be ideal for returning home, but I was maxing out at 4 mph and the winds were picking up. This was the only time I actually used sport mode for more than 10 seconds too. |
