DJI Go 4 Manual*ALL UPDATED*
123Next >
181650 112 2017-11-3
DJI Grace
Flight distance : 405039 ft
Hey guys, DJI Grace here! Today and for the days coming up, I’d like to share with you a series of threads designed to be a comprehensive manual for DJI GO 4. I'm hoping these help you during your flights since there isn’t currently a guide like this from us.
The following part origins from:  BUYING GUIDE
Introduction:
This DJI Go 4 manual will cover the various settings and functions within the DJI GO 4  app for drone operation which can be used as a standalone remote controller for the Spark and Mavic Pro or in conjunction with a remote controller for the Phantom 4 Series, Inspire 2 and the Spark and Mavic. Overall, the app is the gateway to your drone’s settings, so it’s important to understand how the settings work and what they do.
Note this DJI Go 4 manual is focused around Phantom 4 Pro, Mavic, Spark and Inspire 2. Due to different functions of the aircraft some of the screenshots of DJI Go 4 show settings that are available to only certain drones. To save prevent any confusion the aircraft dependent settings are tagged with the aircraft’s name.
DJI Go 4 Manual Contents:
(the ones not underlined mean they're still to be updated.)
Visual Navigation Settings
Camera Settings
Camera View:
You will spend most of your time here when flying your drone as this is your drone’s view of the area in front of it. The icons around the side of the screen will take you to different settings when tapped.
  • System Status: This icon indicates aircraft flight status and displays various warning messages.
  • Obstacle Detection Status: Red bars are displayed when obstacle are close to the aircraft. Orange bars are displayed when obstacles are in detection range.
  • Battery Level Indicator: The battery level indicator provides a dynamic display of the battery level. The coloured zones on the battery level indicator represent the power levels needed to carry out different functions.
  • Flight Mode: The text next to this icon indicated the current flight mode. Tap to configure the MC (Main Controller) Settings. These settings allow you to modify flight limits and set gain values
  • GPS Signal Strength: Show the current number of connected GPS satellites.  The white bar indicates adequate GPS signal.
  • 3D Sensing System Status: Tap this icon to enable or disable features provided by the 3D Sensing system
  • Wi-Fi Settings: Tap to enter Wi-Fi settings.
  • Battery Level: This icon shows the current battery level. Tap to view the battery information menu, set the various battery warnings threshold, and view the battery warning history
  • General Settings: Tap to enter the general settings menu for settings, metrics, enabling live streaming, and displaying flight routes and so on
  • Gimbal Slide: Displays the pitch of the gimbal
  • Photo/Video Toggle: Tap to switch between photo and video recording modes.
  • Shoot/Record Button: Tap to start shooting photos or recording video.
  • Camera Settings: Tap to enter camera settings menu
  • Playback: tap to enter the Playback page and preview the photos and videos as soon as they are captured.
  • Flight Telemetry
  • Virtual Joystick Switch
  • Intelligent Flight Mode: Tap to select Intelligent Flight mode
  • Smart RTH: Initiate RTH procedure. Tap to have the aircraft return to the last recorded home point
  • Auto Take Off/ Landing: Tap to initiate auto take-off or landing
  • Back: Tap this icon to return to the main menu.
System Status:
When you enter camera mode this bar will be one of three colours red, yellow or green. If the bar is green then it means you have a strong GPS connection and it is safe to fly. If it is yellow then it means to fly with caution as the drone may be in ATTI mode meaning it doesn’t have enough GPS signal to maintain a stable position. Finally, if the bar is red it means the drone can’t fly and it will prompt you to take action to fix this situation.
If you tap on the status bar you’ll see an overview of the aircraft systems as follows:
Compass: This lets the drone know where it is and sometimes needs to be recalibrated when you fly from a new location. Pay attention to this as the compass can very easily be disrupted by electromagnetic interference.
IMU (Inertia Measurement Unit): Basically this is a barometer and a gyroscope used by the drone to see its attitude and angle when flying. If DJI Go 4 prompts you to recalibrate it, follow the onscreen instructions.
ESC (Electronic Speed Control) Status: This will tell you if there is a problem with your motors. If you see a warning try resetting your drone, if the warning won’t go away then you’ll need to send your drone in for repair.
Vision Sensors: These are the sensors that check for obstacles when you’re flying. It is strongly recommended that you keep these turned on at all times.
Obstacle Detection Status: This is a visual warning that pops up on your screen when your drone detects that it is close to an obstacle.
This shows you how much power your battery has left. The line gets shorter as the battery power is depleted. The first dot on the left is when the drone will automatically land due to low power. The second dot is when the app will try to activate RTH unless you stop it. The yellow H represent your home point and moves along the line to show how much power you will need to get your drone back home.
Flight Mode:
There are 3 flight modes that can be displayed in the DJI Go 4 app:
Positioning mode (P-MODE): P Mode is when all the drones’ sensors are active, so the drone should always be stable. This is the safest mode to the fly the drone in as if you take your hands off the control sticks then the drone will automatically break and then hover in position.
Attitude or ATTI mode (A-MODE): The aircraft will switch to ATTI mode if there is no GPS signal or it is weak and it is too dark for the Vision Systems to work. The aircraft will only maintain its altitude, but it will drift.
Sport mode (S-Mode): In Sports Mode, your drone can fly at full speed while using GPS for positioning. However, the forward and downward vision systems will be disabled, so they aircraft won’t be able to sense and avoid obstacles. Last but not least Ground Station and Intelligent Flight functions are not available.
2017-11-3
DJI Grace
hey, guys.
So appreciated that this thread is helping you during your flights.
In total there are nine sections of content as following, comprising the entire DJI GO 4 tutorial.
DJI Go 4 Manual Content:  (the ones not underlined means their being update.)
DJI Go 4 General Settings
Main Controlling Settings
Remote Controller Settings
Image Transmission, Battery, Wifi & Virtual Joystick Settings
Gimal Settings
Camera Settings
Intellogent Flight Mode
Miscellaneous
In case some of you miss a thread, I will provide update notices here when I update a new one of the nine parts.
Now, ALL HAVE BEEN UPDATED JUST CLICK AND SEE
1. DJI Go 4 General Settings: https://forum.dji.com/thread-118399-1-1.html
2. Main Controlling Settings: https://forum.dji.com/thread-118653-1-1.html
3. Visual Navigation Settings: https://forum.dji.com/thread-118688-1-1.html
4. Remote Controller Settings: https://forum.dji.com/thread-118768-1-1.html
5. Image Transmission, Battery, Wifi & Virtual Joystick Settings:  https://forum.dji.com/thread-118769-1-1.html
6. Gimbal Settings: https://forum.dji.com/forum.php?mod=viewthread&tid=118954
7. Camera Settings: https://forum.dji.com/forum.php?mod=viewthread&tid=118959
8. Intelligent Flight Mode: https://forum.dji.com/forum.php?mod=viewthread&tid=118962
9. Miscellaneous: https://forum.dji.com/forum.php?mod=viewthread&tid=118964
Happy flying, guys!
2017-11-5
prite
Flight distance : 432602 ft
brill, thank you, a must read for the newbe flyer
2017-11-3
Ryan's Sparky
Flight distance : 302316 ft
Norway
thanks its good to have a clear understanding of what everything means
2017-11-3
fans0c10c3ea
Thank You!!!
2017-11-4
Woe
Flight distance : 4129268 ft
Thank you for the great info
2017-11-4
hallmark007
Flight distance : 9827923 ft
Great job dji Grace, do you think we might get a manual explaining some of the warning pop ups. I.E. speed error yaw error and so many more that users are left to their own devices to figure out?
Keep up the good work you are doing a great job.
2017-11-4
Kansas Boy
Flight distance : 26145 ft
Thanks for publishing.
2017-11-4
embayweather
Flight distance : 556667 ft
An excellent post, thank you for doing this.
2017-11-4
Viking-Pilot
Flight distance : 2379249 ft
Very good info, thanks for sharing,
2017-11-4
allyssongemelli
Flight distance : 2562467 ft
Brazil
Very good. There i a possibility to share an PDF file of the manual?
2017-11-4
AEM74
Flight distance : 332677 ft
+,1 thanks! Really useful guide to get more familiarized with the app.
2017-11-4
ALABAMA
Flight distance : 10442687 ft
Informative for all! Thanks for posting
2017-11-4
Dockater
Flight distance : 139649 ft
prite Posted at 2017-11-3 23:28
After reading some of the posts here this is not only good for neubies.
2017-11-5
Montfrooij
Flight distance : 2560453 ft
Thanks a lot.
I almost want to say: finally!
2017-11-5
Gabto
Flight distance : 33202 ft
Argentina
The real help for the "non english speaking" market would be THE TRANSLATION OF THE SOFTWARE...
Not only the soft is in english... now a fixed entry of the forum offers an ENGLISH tutorial... jejejejeje
I have no doubt it would be of help to the "english newbes", but we (the "others") are still waiting for something as basic on this times as a "languaje selection" in the app (not only english and chinese, but spanish, french, italian, portuguese, german, and..........)
2017-11-5
DJI Grace
allyssongemelli Posted at 2017-11-4 11:24
absolutely possible!
after all the content related are updated, i will make them into PDF for you guys then you can save them and look through them whenever and wherever.
2017-11-5
FatherXmas
Flight distance : 4058619 ft
DJI Grace Posted at 2017-11-5 17:47
That will be great! Thanks so much!
2017-11-5
DJI Grace
FatherXmas Posted at 2017-11-5 18:50
You are welcome!
Honestly, I think that is definitely great idea!
2017-11-5
DJI Grace
Gabto Posted at 2017-11-5 15:46
Hey, Gabto
I totally got what you mean and your desire.
there is "REGIONAL" section on our forum, and I know not so many people talk or discuss there.
We are improving on that, please don't be worried.
As for the tutorials, you could create a thread or poll to appeal our users on the forum, we may choose the top three language to provide alternative copies?
Is this will be ok?
If you have any good ideas, just freely to contact me.
Regards,
Grace
2017-11-5
m1shootr
Flight distance : 118894 ft
Thanks for posting!
2017-11-6
Silver Surfer
Flight distance : 46283 ft
DJI Grace Posted at 2017-11-5 19:19
hey, guys.
So appreciated that this thread help you during flying.
There are totally nine contents as following, making up the whole tutorial about DJI GO 4.
Thank you Grace, for a very helpful tutorial thread.  Looking forward to going over the ones that are
being updated ("The ones without underline means updating).
Happy flying
2017-11-6
DJI Grace
Silver Surfer Posted at 2017-11-6 16:38
Happy flying
Thank you for your reply and I have updated 4. You can click on the link in my top reply!
Hope that helpful!
2017-11-6
Floyd-Spark
Flight distance : 52644 ft
Excellent work Grace
2017-11-6
DJI Grace
Like it?
I updated a new one, the fifth part of it. just click and check.
2017-11-6
Montfrooij
DJI Grace Posted at 2017-11-6 18:19
Hope that helpful!
Great addition!
2017-11-7
Kenneth R.
Flight distance : 201850 ft
Bulgaria
Please make these into downloadable PDF's that can be brought on our Phones on "the fly"
2017-11-7
Cetacean
Flight distance : 2528264 ft
hey, guys.
Aloha Grace,
     Mahalo for the great job!  My apologies for not posting this "Mahalo Nui Loa!" sooner, but I have been reading your work.  I look at it and suddenly, I am out of time!  This is a very helpful format because the links allow you to get your specific information without looking for so long.  The .pdf format will allow us to use it on the "fly" as they say.
     Mahalo again!
Aloha and Drone On!
2017-11-8
F.KOK
Flight distance : 18954370 ft
Namibia
Thanks Grace, keep the good info you posted coming it's useful.
2017-11-8
DJI Grace
F.KOK Posted at 2017-11-8 22:15
Moving on!
Appreciated your support here!
2017-11-8
Genghis9
Flight distance : 961 ft
THIS is exactly the stuff we need to see, and this definitely fills a need and gaps in DJI product support.  Thank You!
2017-11-9
M.C. Pilot
Flight distance : 10278435 ft
Reasonable, helpful tools to have available so thanks.
2017-11-10
DJI Grace
Genghis9 Posted at 2017-11-9 10:48
thank you for your support and very glad you like it!
2017-11-11
DJI Grace
M.C. Pilot Posted at 2017-11-10 19:05
the whole tutorial is sooo long and I divide it into 9 parts with link above, Check it and feel free to ask anything here
2017-11-11
Bekaru Tree
Flight distance : 15513100 ft
South Africa
hey, guys.
thanks dji grace - good opportunity to go through the manual again with a fresh review
2017-11-12
Lauren DeLoach
Thank you for your hard work, excellent guide!
2017-11-13
EdM
Flight distance : 1491814 ft
Thanks.   Now all we need is the PDF version.    Hint....Hint.
Accounting for the future changes is what will drive you crazy.
Good job!
2017-11-13
Exact Science
Droid -
How do I change the user logged into the program / ap?
If someone else wants to use their account on my device.
How do I go about logout?
I cannot find where I log out and log back in wi
2017-11-14
DJI Susan
Exact Science Posted at 2017-11-14 08:41
Droid -
You can log out DJI GO from here: Me>Settings(the right upper corner)>Sign out.
2017-11-14
Exact Science
DJI Susan Posted at 2017-11-14 18:29
Thanks Susan, I couldn't see the flower icon top right corner but I do now.
Where can I download previous versions of the DJI GO ap for droid?
Thanks for your help
2017-11-14
123Next >
