The following part origins from: BUYING GUIDE
DJI GO 4 General Settings:
This is where you can adjust the general settings. Measurement Units: Here you can choose how your parameters are displayed in DJI GO 4 and you have a choice of in m/s, km/h or Imperial units. Long Press Action: This can be set to either Gimbal Control or Focus. If set to Gimbal Control then when you long press the screen you will be able to move the gimbal up and down by dragging your finger. If set to Focusthen when you long press the screen a green box will come up showing the focus of the composition. Live Streaming: Here you can enable live streaming to Facebook or other popular social media platforms. To enable it all you have to do is choose your preferred platform and log into your account then follow the on-screen prompts.
Map:
In the Map settings you toggle on and off Show Flight Route and Cache the Map in the Background which means that DJI Go 4 will store the local map, so it doesn’t need to download it every time. The Calibrate Map Coordinates (For China Mainland) unless you live in China keep this turned off. If you do live in China then turn it on for accurate GPS positioning.
Video Cache:If this is enabled then DJI Go 4 will save videos to your phone as well as your SD card. If enabled you can set the maximum amount of space you want to use for video cache as well as setting it up to automatically clear space once a certain amount of disk space is used. The last setting is Record Audio with the Video Cache and if this enabled it means your mobile device will record the audio around you when you take a video.
