BumblerBee
Flight distance : 639764 ft
Norway
Actually, looks like the OP is correct, after all. What I found earlier was proposition for a 150m limit in Russia.
Current rules are best outlimed here:
https://pikabu.ru/story/razyasne ... spilotnikam_5067952
You do not need to certify pilot, you do not need register the pilot of the drone, the drone cannot be confistacted by the police even if you broke the rules (unless emergency or martial law is in efefct), and you cannot fly in the restricted airspace.
Moscow is classified as "restricted from gnd to 8100m MSL", meaning that you can fly above that limit.
Other than that, the common rule of keeping away from airports, helipads and military sites applies.
No fly zones can be viewed here: https://fpln.ru/
(Select the options under the first "wind rose" icon in the upper center of the screen).
I read elsewhere that the authorities got so tired of people flying over Red Square that GPS a repeater got installed, covering the area and projecting Vnukovo airport coordinates, so that the drones would think that they are in an internationally recognised NFZ and would not start motors. No idea if that is true, though.
Here is a screenshot of NFZs over Moscow, with air corridors, airports and helipads plotted in.
