JeremyPCP
Flight distance : 16076 ft
Just got it in last night. It looks from the serial number to be the same aircraft. I am very disappointed in the way they repackaged it. When I sent it to DJI I had everything snugly placed in their corresponding areas of the stock foam travel case, then the case was double boxed and surrounded by 1.5inch sheets of corrugated studio foam. What DJI sent back sounded like something heavy was clunking around in the box. When I opened it i found a signal cardboard box with no padding in it other then the travel case, and inside the travel case was my controller haphazardly flopping around causing many dents to the interior of the travel case. When I took out the aircraft i noticed scratches all over the landing gear legs, the rubber plugs at the end of the aircraft legs were falling out, and the entire drove was covered in some kind of sand or large dust particles. Im also surprised that they didn't replace the propellers I sent back with the drone as they are the ones DJI has said are defective. I thought for sure they would have sent me the ones with the foam inside or whatever else they now have out.
I just took the drone out for 2 flights and both times was scared out of my mind. The shake once the landing gear is up is even worse then before and twice it sounded almost like the front motors cut out as the whole drone almost went nose down before dramatically correcting itself (this was only about 8 feet off the ground with no wind). This motion caused the drone both times to take up approximately 20 feet of lateral room just to correct itself while still shaking out of control. Had I been filming a wedding or even landscape work this kind of action could cause it to hit a tree, building, or person.
So in total, not only did DJI trash my drone by adding scratches all over it, they also trashed the travel case internal, Neglected to replace the propellers they themselves say are factory defective, and whatever they did do caused the drone to be even more unstable and dangerous. So now I am invested in about $10,000 of equipment that is not only completely useless and dangerous, but it has almost no resale value thanks to whatever they did to it. I have now gone from disappointed to very upset.
Please DJI this has to be fixed ASAP. I need something that works and justifies my investment. |
