S-e-ven
Flight distance : 5922034 ft
Thailand
Sliderul Posted at 2017-11-13 21:09
I'm a little surprised that no one has mentioned the "find my drone" feature in DJI GO4. My Spark was caught in a whirlwind and I lost connection and the drone. After getting over the panic I recalled seeing the feature as a menu option in DJI GO4. I accessed the feature by tapping the menu in the upper right corner of the app. Tap on "Find My Drone" and you get a map that shows your position (assuming you have GPS working on your phone) and the position of the drone. I had to travel about 1/4 mile and according to the map I was in the right location, but couldn't see the drone. Then I found a feature on the screen that forced the drone to give an audible signal. Thirty seconds later I found the drone at rest on a child's slippery slide, still on and sending a location signal.
You were lucky in 2 cases:
First, you "lost"your drone, but the drone did not loose GPS or connection, or went to atti mode.
Second, you reached the position during the battery power time.
p.ex., I tried the "find my drone" feature one time, to test. Yep, it showed me the last position of my last flight, jut before I switched it of: About a thousand km away, but resting on the desk.
It is a nice function, but in case of atti fly away and/or connection loss and no RTH, you have only a refrerence point.
The very last known position of your drone
Very useful in case of critical battery landings, methinks
Aside, indi75 mentioned it in his sec. post ;-) |
