When i switch on rc and ac to check and setting everything at home before weekend we plan to go bintan for holiday. I tested video for 4k and 30fps. it happen like gimbal video suddenly show "No signal" and gimball moved from left to center like that. I removed all propellers. i tried to use my hand to hold AC and walked around with video tested and happen sometime like that. I saw other mavic pro link happen same as me. https://forum.dji.com/thread-116037-1-1.html My phantom is already out of warranty. Is problem gimbal or app or FW?
DJI Elektra Posted at 2017-11-12 00:18
I would recommend you flash the firmware and see if it works well. What is the model of your drone? Did you calibrate the gimbal before?
Hi. My model is only phantom 4. I already did calibrate the gimbal many time still not work and 4k 30fps stop and reset happen. My friend gave me beta flash v02.00.0600 and tested it very stable well. no issue. later will test if got wobble or not
I already tested v02.00.0600 still very stable. 4k 30fps fine no more stop video and reset. wobble no more and look fine. Only RC button playback cannot press when new BETA v02.00.0600 AC. old bug v02.00.0106 AC got RC press playback button
