Request. Please add dng picture format
1353 11 2017-11-6
Anuvis
Flight distance : 1976736 ft
Greece
Please DJI give us .dng file format not only .jpg.....
2017-11-6
djiuser_FvG7O5M
Flight distance : 84767 ft
Absolutely agree. Please DJI give us .dng file format
2017-11-6
DrawsWithLight.
Flight distance : 2136716 ft
That would be awesome, can't see it happening though
2017-11-6
Anuvis
Greece
So let's make it official go to use ski go app open dji support and make a suggestion.... If they have many same suggestions maybe they will add it eventually....It is easy add on software...
2017-11-6
Wachtberger
Flight distance : 261509 ft
May I ask which advantages you expect from .dng picture format? Or are you talking about .png which is even worse?
2017-11-6
Lyons90
Flight distance : 164528 ft
Isn't .DNG just Adobe's proprietary version of .RAW??
2017-11-6
FatherXmas
Flight distance : 4058619 ft
Lyons90 Posted at 2017-11-6 13:52
.DNG is an Adobe creation but is not proprietary. As I understand it, they pushed to have it become the .RAW standard but no one went along with it.
2017-11-6
Montfrooij
Flight distance : 2560453 ft
Wachtberger Posted at 2017-11-6 13:39
It is a kind of raw format.
This will give you a little more headroom with editing.
Don't expect miracles with Spark's tiny sensor, but it is better than Jpeg.
2017-11-6
Montfrooij
That would be great, although you could also benefit a lot from a flat profile to be able to save more details in the low- and highlights.
2017-11-6
_pk
Flight distance : 696 ft
Poland
DNG (i.e. raw) advantages are: a greater dynamic range - 12 or even 14 bits of accuracy gives you much more room to lighten dark parts of picture of recover details in highlights without artifacts (like posterization). Another advantage is that raw images are not sharpened, hence... they contain more details. Yes, I know it may sound surprising but this is true (actually mathematically provable). BTW, imho DJI's jpegs are far too oversharpened by default.
2017-11-6
Anuvis
Greece
Exactly that Montfrooij says.Spark .jpg is ideal when taking photos daylight or with a descent amount of light...BUT in low light conditions such as cloudy weather .jpg with compress and low light can produce a lot noise.....If you take the shot with .dng in low-light and push it to light room without .jpg compression, you will have  a lot less noise,  a clearer picture with greater results.Plus you import it to LR and make little miracles....
2017-11-6
Wachtberger
Thank you all for the explanations!
2017-11-6
