BumblerBee
Flight distance : 639764 ft
Norway
The promised sunny and calm weather this week-end turned out to be calm, yet foggy. Really foggy.
The visibility at ground level was about 50 meters, so I decided to give it a go. The flight consisted of a few short foreys around the neighbourhood at an altitude of 50-70 meters, followed by an experiemt, where I climbed above the take off spot, straight up to 120m, noting how the view of the ground gradually disappered, also noting at which altitude I would lose sight of Mavic. The flight was done with the new propellers.
Here is a video of a few moments form the flight (using SkyPixel as that's still the easiest platform to upload to directly from DJI GO)
Here are a few points of interest to note:
- Fog shifts quickly. A spot where you for a second may have a good 200m of visibility can quickly turn into 30-40m.
- I could hear Mavic up to 50m up with the new props when hovering, afther that it went completely silent.
- I have a white Cree strobe light attached to the bird. While I lost sight of the Mavic's silhouette at about 50m above me, the blinks from the strobe were visible until Mavic was about 70-80 meters up.
- It is very easy to become disoriented in the fog. I had to switch to map view and point camera straight down on many occasions to get my bearings, even though I was never further, than 250m away and over a well-known area.
- Having a helipad on the ground (orange side up) is helpful when returning at altitude - it was the last thing to disappear from view in the straight up test.
- After the flight I noticed fine droplets of condensation from on the following areas: upper and front surfaces of the arms, and on the upper rear of the body, where white DJI logo is located. The rest of the bird was dry. In sub-zero foggy conditions such condensation can freeze, build up and result in added weight.
