Are vids from spark to iPad worse quality than direct from SD card
890 6 2017-11-6
PFrancis
Flight distance : 4459 ft
Just took some video with the spark.Not messed with any settings or anything and looking back at them after I transferred the files from spark to dji app/iPads camera roll the quality seems grainy in parts and not very smooth.Is the quality better transferred directly from the SD card to a PC?
2017-11-6
Lyons90
Flight distance : 164528 ft
Yes, low res copies on the handset, full res on sd card
2017-11-6
TexasAerials
Flight distance : 566952 ft
the video saved by default on the device is at best 720p, but is limited to the quality of the downlink signal.  You can download the full-quality file to the device through the editor in DJI Go4
2017-11-6
DJI Elektra
I would recommend you view the high res video in PC for better performance.
2017-11-6
Oldmaninwva
Flight distance : 9750253 ft
jilan102 Posted at 2018-5-22 23:37
personal fax cover sheet template pdf
General fax cover sheet pdf download
Printable fax cover sheet template download
If enough REAL users report these types of posts, the posts as well as the users posting them will be flagged for removal.
2018-5-23
Nehalp8295
very good job man
2018-5-25
MalleeBrad
Flight distance : 21161 ft
So as a new user, the quality stored on the SD card is better than on the phone via the App?  I am disappointed with the quality of the video so far, but arent storing on a SD card.
2018-11-25
