*DJI Go 4 Manual*Remote Controller Settings
17006 9 2017-11-6
DJI Grace
Flight distance : 405039 ft
The following part origins from: BUYINGGUIDE
Remote Controller Settings:
Here you can configure your remote controller’s settings.
Remote Controller Calibration: Here you can calibrate your remote controller’s sticks and toggle wheels. You can only calibrate the RC when the aircraft is turned off. To calibrate just follow the on-screen instructions.
Stick Mode: This is where you can choose the stick mode for how to fly your aircraft, the default joystick mode is 2 for both the remote controller and the virtual joysticks. At present, only the Mavic and Spark supports virtual joysticks.
Set to Fixed-Wing Mode: Here you can toggle fixed-wing mode on and off. In this mode, the drone will fly forward automatically at a certain speed after entering Fix-Winged Mode. Push the left stick up to ascend and down to descend. Push either stick left or right to rotate the aircraft.
Remote Controller LCD Screen Introduction: This screen will give a brief overview of what you are seeing when you look at the Remote Controllers screen. (Mavic Only)
Button Customization: You can set what the C1 & C2 button do when pressed. You have a choice of:
Turn on/off Front LEDs turns the aircraft’s front LEDs on or off, so you avoid glare when you take photos.
Centre-weighted Metering tells the camera to evaluate the light in the middle of the frame.
AF Lock/Unlock locks or unlocks the autofocus.
Advanced camera settings for quick access to ISO, Shutter and EV settings.
Camera Forward/Down will switch camera direction from facing forward to 90° down.
Gimbal follow/FPV mode. Follow mode (Phantom 3 series only) is the one we usually use for video shooting, supports 3 axis stabilization. FPV mode locks Roll axis stabilization, so the pilot can see the camera’s horizontal tilt while turning or going sideways.
Toggle map/live view brings the map to the full screen.
Clear flight route function clears the past route line on a map.
Battery info shows voltage and capacity left in the battery.
Playback shows you your photos or videos
Centre Auto Focus makes the camera focus on the centre of the frame
Right Dial ISO/ Shutter Control alternates what the right dial controls
5D Button Customization:
Here you can control what the 5 D joystick button does, you have a choice of (Mavic Only)
Zoom In makes the camera zoom in.
Zoom Out makes the camera zoom out.
Portrait Mode makes the camera rotate into a verticle position (Mavic)
Focusing/Metering switches between focus and metering when in manual focus.
AE Lock locks the focus and exposure values when taking a photo.
Other Settings:
Remote Controller Type: Here you can set a controller as master or slave.
Linking Remote Controller: To link the remote controller to the aircraft.
2017-11-6
DJI Grace
hey, guys
Here is one part from the "DJI Go 4 Manual".
click here if you want to know more about the whole parts. https://forum.dji.com/thread-118397-1-1.html
Enjoy and tell about how this may help and what do you think
2017-11-6
DJI Grace
Thank you for always supporting me!
2017-11-14
DJI Grace
You are welcome! Enjoy in our community!
2017-11-14
Lucas775
Flight distance : 50642090 ft
Thank you for this.
2017-11-12
Montfrooij
Flight distance : 2560453 ft
Nice piece of info
2017-11-14
Montfrooij
DJI Grace Posted at 2017-11-14 18:27
That's just me
2017-11-14
Easy Ed
Flight distance : 41414 ft
nicely done - thanks for sharing.
2018-11-2
G37 Mavic Pro
Flight distance : 49741 ft
Thanks for sharing
2019-7-31
droneroBCN
Hola estoy buscando como desactivar la vibracion del mado  del phantom 4 pro plus v2, saludos
2019-11-15
