camera problem mavic pro
1132 3 2017-11-7
izzbax
Israel
After having an accident with a pelican in Acapulco Bay last week,I can not control the position of the camera(mavic pro).I can take pictures and video.
My question is if it is possible to change separately the camera or the electronic board.Or it must be the camera and the board together as a module.
Thank you.
2017-11-7
DocAraxá
Flight distance : 202283 ft
Brazil
You have 3 options:
- Flex ribbon cable;
- The gimbal itself;
- Eletronic board.
It should be tested to be sure about the problem.
2017-11-7
Bekaru Tree
Flight distance : 15513100 ft
South Africa
i do not know the answer but maybe check out some videos on you tube. Try this url as starting point https://www.youtube.com/results?search_query=fix+mavic+camera
2017-11-7
DJI Thor
Flight distance : 13602 ft
Please check the gimbal settings, try to reset it. If it doesn't help, and it is confirmed that was damaged by the accident, please contact support@dji.com for a further help.
2017-11-7
