*DJI G0 4 Manual* Gimbal Settings
19681 16 2017-11-8
DJI Grace
Flight distance : 405039 ft
The following part origins from: BUYINGGUIDE
Gimbal Settings:
Here you can adjust how your gimbal moves.
Gimbal Mode:
There are 2 choices Follow and First Person View (FPV).
Follow: In this mode, the camera will remain stable and maintain the horizon
FPV: This orients the gimbal with the movement of the drone. So when you change the orientation of the drone the camera view will move with it.
Centring Camera: If you tap this then the camera will move into centre place horizontally or straight down.
Adjust Gimbal Roll:  You can use this to adjust the tilt of the gimbal if it is misaligned. You can do this when flying rather than having to bring your drone back to fix it.
Gimbal Auto Calibration: The drone will automatically try to centre the gimbal, this must be done when the drone is on a level surface.
Advanced Settings:
Here you can set gimbal functions.
Gimbal Pitch Speed: This controls the speed at which the gimbal tilts. A higher value means a faster-moving gimbal and lower value means a slower gimbal.
Enable Upwards Gimbal Tilt Limit to 30 Degree: Turn this off will allow the camera to tilt up beyond 30, but you’ll be able to see the propellers in any shots you take. Unless you are flying backwards.
Gimbal Pitch Smoothness: This controls how quickly the gimbal will come to a complete stop after you move it. A lower value means a quick stop and a higher value means a slower stop.
Enable Synchronized Gimbal Pan Follow: Enabling this makes the camera move with the yaw stick. This helps videos to be smoother when you move the yaw stick.
LEARN MORE
2017-11-8
DJI Grace
hey, guys
Here is one part from the "DJI Go 4 Manual".
click here if you want to know more about the whole parts. https://forum.dji.com/thread-118397-1-1.html
Enjoy and tell about how this may help and what do you think
2017-11-8
Floyd-Spark
Flight distance : 52644 ft
Awesome Grace. We are lucky to have you.
2017-11-8
DJI Grace
Floyd-Spark Posted at 2017-11-8 21:40
Thank you soooo much for the comments,
Enjoy discussion and sharing here
2017-11-8
Montfrooij
Flight distance : 2560453 ft
Great addition
2017-11-14
B3nZ3n
Flight distance : 26486 ft
New Zealand
Hi!
I noticed that I don't have this setting available in the app for my mavic pro..  Looks like the gimbal icon setting is missing..
App v 4.1.15 on android 7.1.1 (Oneplus 3T)
(sorry if this is the wrong thread)
2017-11-14
DJI Susan
B3nZ3n Posted at 2017-11-14 17:49
Hi!
Please power on the aircraft and controller, then connect with your APP, Gimbal icon will be displayed here, just have a try.
2017-11-14
guillermo1975
Flight distance : 49085 ft
Argentina
Hi!
I have the same problem. Did you find a solution for Android?
2018-2-26
guillermo1975
Argentina
DJI Susan Posted at 2017-11-14 18:34
That was the answer!! Thanks a lot Susan!!!
2018-2-26
DJI Susan
guillermo1975 Posted at 2018-2-26 13:40
You are welcome! Should there is any further question, feel free to contact us.
2018-3-2
Ceeps
Flight distance : 87441 ft
I have a mavic air and the Enable Synchronized Gimbal Pan Follow is not there so where I move left and right it is sharp and not smooth on the video any idea?
2018-7-27
DJI Susan
Ceeps Posted at 2018-7-27 13:14
Hi Ceeps, I'm sorry that Mavic Air does not have the option of Enable Synchronized Gimbal Pan Follow for now. Regarding the recording during the flight, it is recommended to select Follow Mode and set a proper pitch speed and smoothness value to check, you may also try to reset settings.
2018-7-28
G37 Mavic Pro
Flight distance : 49741 ft
Thanks for sharing
2019-7-31
kri2tof
Belgium
this is really helpful thanks
2019-12-7
Gerard31650
Hello, I am not sure to be in trouble with my Mavic Air, bur when I move from left to right or right to left, the horizon does not stay horizontal. I have recheck the gimball different adjustement and use the "follow" mode. I had a small scratch but I cant say if before, it was OK because I own the drome since a couple of weeks only. Thanks for your help. Gérard..
2020-3-8
djiuser_lZWwtkl0s00g
India
Hi I have tried restart but still gimbal status is N/A. Also no movement in the gimbal when the drone is switched on.
It was working a week back and no crash history. All went wrong only after upgrading the firmware
2020-6-26
Chrislatino
Hi!
Hello Guys,
I ve got exactlly the same problems,: Gimbal Settings Menu Not Present on the DJI GO 4 with Mavic 2 Zoom
I ve allready upgraded everything and re install Dji go 4 !!!
Have found any solution please ?
thanks
Chris
3-12 09:00
