Aircraft Failed Firmware upgrade
2981 18 2017-11-8
fans7ae36040
Hi,
I have an Inspire 1 (x3) that I am trying to upgrade to v11.01.50.  The aircraft will make the ordinary beeps when it is going through the firmware upgrade.  However, about 4-5mins into the upgrade it has a long beep.  I still have control of the aircraft via remote, however, I am unable to see any video.  Everything seems normal with the aircraft with exception of the firmware upgrade problem.  Any help on how to fix this would be greatly appreciated! The text file reads this:
ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ=
Packet: WM610_FW_V01.11.01.50.bin
========== 2014.01.01 00:00:07 remo-con disconnect======
Upgrading ...
========== 2017.10.28 10:05:17 =====================
Upgrading ...
Result: Success.
========== 2014.01.01 00:00:06 remo-con disconnect======
Upgrading ...
========== 2017.11.04 13:26:45 =====================
Upgrading ...
Result: Failed.
Reboot the aircraft and try to upgrade the firmware again.
Upgrading ...
Result: Failed.
Upgrading ...
Result: Failed.
Upgrading ...
Result: Failed.
Upgrading ...
Result: Failed.
Upgrading ...
Result: Failed.
Upgrading ...
Result: Failed.
2017-11-8
Keule
Flight distance : 3733015 ft
Never leave the RC on while updating the aircraft!
- Turn OFF your RC
- Turn ON your AC, with firmware on SD card.
Again, leave RC OFF while update, wait for update is being finished.
2017-11-8
fans7ae36040
Keule Posted at 2017-11-8 11:44
- Turn OFF your RC
Sorry, I don't think I clarified.  The RC was OFF during firmware upgrade and I am aware not to leave it on when upgrading.  What I meant was when the aircraft is not conducting an upgrade, I can connect to it fine and it responds fine, but I cannot see video.  I believe the firmware upgrade is the problem though.  It fails everytime I try to upgrade the firmware.
2017-11-8
Keule
What is your current firmware status seen in 'about' section of GO app?
2017-11-8
PapaFox1985
Keule Posted at 2017-11-8 12:04
It shows 1.2.1.0+, everything else is current but the aircraft.
2017-11-8
Keule
Am i talking to fans7ae36040 or PapaFox1985 ?
2017-11-8
PapaFox1985
Keule Posted at 2017-11-8 12:28
Same person, sorry I just changed my avatar name.  I am not new to "drones", rather I have been flying UAV's for over 10 years for the military and as a contractor.  However, I am somewhat new to DJI products.
2017-11-8
Keule
Roger that.
It seems that your AC firmware and your RC firmware are way out of sync.
I recommend to downgrade the RC to match the AC version. (Maybe a relink between AC/RC must be done again)
It's necessary because DJI changed the encryption scheme sometimes in between.
So, when you are able to see the video feed and you can control/fly the aircraft, then start updating 1 version to the next only
I'm not sure which version you can skip, to be on the safe side, update in sequence.
You can find old firmware here: http://www.panorobot.com/dji/inspire_firmwares.htm
2017-11-8
PapaFox1985
Keule Posted at 2017-11-8 12:49
Roger that.
Awesome!  I will give it a shot and update as I complete it!  I believe I will have more time tomorrow to try it out, either way, I will send an update.  Thanks for the help!
2017-11-8
Is the current firmware version of the aircraft 1.2.1.0+?
Long beep sound means the update was failed. If it fails again, please show us the log details of update, which can be found in hidden files: \MISC\LOG\WM610_FW_LOG_AB.txt.
2017-11-8
PapaFox1985
DJI Mindy Posted at 2017-11-8 23:42
Hi Mindy,
That is correct, it is on version 1.2.1.0+.  Here is the log details below.  The firmware upgrade keeps failing.  When I am not trying to do the upgrade, I still have control of the aircraft, just no video.
Upgrading ...
Upgrading ...
Result: Success.
Upgrading ...
Upgrading ...
Result: Failed.
Upgrading ...
Result: Failed.
Upgrading ...
Result: Failed.
Upgrading ...
Result: Failed.
Upgrading ...
Result: Failed.
Upgrading ...
Result: Failed.
Upgrading ...
Result: Failed.
2017-11-10
PapaFox1985
Roger that.
Hello,
I tried updated the firmware starting from the first firmware upgrade.  Still is not updating the firmware.  I then tried the 2nd firmware update, still wouldn't work.  Here is the error that I am getting:
Upgrading ...
Upgrading ...
Result: Success.
Upgrading ...
Upgrading ...
Result: Failed.
Upgrading ...
Result: Failed.
Upgrading ...
Result: Failed.
Upgrading ...
Result: Failed.
Upgrading ...
Result: Failed.
Upgrading ...
Result: Failed.
Upgrading ...
Result: Failed.
Packet: WM610_FW_V01.02.01.03.bin
Result: Corrupted.
Firmware bin file is corrupted, download it again from the DJI offical website.
Packet: WM610_FW_V01.02.01.06.bin
Result: Abort.
The current firmware does not support downgrade. Use a different version of firmware to downgrade the target version.
Packet: WM610_FW_V01.08.01.00.bin
Result: Abort.
Result: Abort.
========== 2014.01.01 00:00:05 remo-con disconnect======
Result: Corrupted.
Result: Abort.
2017-11-20
Håkan K
Flight distance : 262946 ft
Sweden
This one seems to have succeeded:
Upgrading ...
Result: Success.
You have several too old packets your tried to update with and some seems to be reported being corrupted.   I would try to format the SD card in the craft, copy the latest FW and make an attempt again.
2017-11-20
PapaFox1985
Håkan K Posted at 2017-11-20 07:26
When I try to update the firmware with the new one firmware, the light blinks yellow.  I do not get the upgrade failed beeps, but if I let it sit for a while and then shut it down and remove the SD card, there is no firmware upgrade log file.  Any suggestions?
2017-11-20
Håkan K
Sweden
Did you try format the SD card in the craft with the DJI GO app? Then copy over WM610_FW_V01.11.01.50.bin to the SD card and start up the craft?
2017-11-21
PapaFox1985
Yep, I tried formatting the SD card through the app then installing the firmware onto the SD card.  I also tried the debug file and still no progress.  I am stumped...any suggestions?
It comes up with this in the text file.....
Upgrading ...
Upgrading ...
Result: Success.
Upgrading ...
Upgrading ...
Result: Failed.
Upgrading ...
Result: Failed.
Upgrading ...
Result: Failed.
Upgrading ...
Result: Failed.
Upgrading ...
Result: Failed.
Upgrading ...
Result: Failed.
Upgrading ...
Result: Failed.
Result: Corrupted.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Corrupted.
Result: Abort.
Upgrading ...
========== 2017.11.27 09:16:50 =====================
Upgrading ...
Upgrading ...
Result: Failed.
Upgrading ...
Result: Failed.
2017-11-27
PapaFox1985
Here is the current firmware information:
App 3.1.23
V 1.2.1.0+
Camera 1.10.01.40
RC 1.7.80
I have control but no video from camera.
2017-11-27
PapaFox1985
It still comes back failed when I try to upload the new aircraft firmware in it....
2017-11-27
Vliegelientje
Flight distance : 13232 ft
I have the same problem. Can you post the solution, please?
2019-6-19
