It seems that any changes I make to the settings in the app are not saved. Each time I change the camera or video settings and restart the app the changes are gone. What am I doing wrong?
Rolling got it, most of the settings you select are saved to the AC itself not the App, if they were saved to the app you would have the same settings applied to every AC that is connected to the app.
Your remote and MP have to be on and connected when you make the changes, then the changes go to the MP and will be there next time you connect or fly.
Do you still have the same problem?
Do you mean the camera settings will not be saved? Like the EV, resolution?
What is the APP version you are running?
I'm just starting with my Mavic Pro... Only 5 short flights... But it's great.
This topic is a very good point and opportunity for DJI..??
Could you not have a save "Flight Profile" option.
So I make all my settings/adjustments and have a "Save As" option..
Give it a name like "Winter Snow Scene - Slow" or "Mountains Cloudy - Fast"
When I next "connect" to drone it ask you to select :
Use current profile "Winter Snow Scene - Slow"
or Load Another >> this takes you to a list of profiles
or Create New >> this allows you to start a new profile
The connection between the unmanned DJ Pro 4 and the remote control has been interrupted and the last coordinates in the DJ Pro 4 program have not been saved or fallen. The location of the drone is not clear how I should find it
