RADROCKET
Flight distance : 1110827 ft
Create an account on www.dji.com.
Download the DJI Go app (DJI Go, NOT DJI Go 4) from the App Store or Google Play Store.
Power on your remote controller by pressing the power button for 1 second, releasing it, and then pressing it again for 3 seconds. Then do the same to power on the aircraft.
Connect a compatible mobile device with your Phantom 3 standard via WIFI. The default password is 12341234.
Go back to the app and it will ask you to activate your aircraft.
Then follow the instructions in the app to name your aircraft. You can change the name later in the app if you want.
Choose a Stick Mode. Mode 2 is the default mode, and you can set a custom mode after activation if you want.
After all this, the app will ask you to switch the WIFI to your home WIFI network. Follow the steps in the app to finish activation.
Check out this tutorial for a visual walkthrough:
If the activation fails or the aircraft disconnects during the process, you can troubleshoot with the following steps:
1. Try using an Android device if you’re using an iOS device, or vice versa. Get everything connected and try again. Check this site to see which mobile devices are compatible with DJI Go: http://www.dji.com/phantom-3-standard/info#downloads
2. Try to register with another email account on the DJI website then log into your app and try to activate again.
3. Try another WIFI network or 4G to ensure internet stability. |
