crash1sttime
Flight distance : 1047503 ft
solentlife Posted at 2017-11-10 02:50
Hi .. my post was poorly worded ...
ALL flights should be AIRPLANE mode whatever Phantom you have ... what I meant with Adv / Pro - is that WiFi does not need to active .. its only with Standard you need WiFi to connect to Controller.
All flights on Airplane mode, interesting, just how do you come to that conclusion?,
Ive had many long distance flights and have hours of flight time under my belt flying P2V, P3A and a mavic and not once have i found a reason to use Airplane mode, i will however concede that AM was advised to flyers of the P2V and P2V+ due to them using Wifi and having possible interference from mobile data but other than that there isnt any provable evidence that AM should be used, with exception to my point about the P2V etc.
I take it that the caps are there to stress your slightly misguided view, I wont use caps unless necessary. |
