Mark The Droner
Flight distance : 2917 ft
What you want is this, but you also need the servo motor which is not included.
https://www.amazon.com/Phantom-V ... ion+damping+bracket
You will also need the four rubber dampers.
https://www.amazon.com/DJI-Phant ... om+2+vision+dampers
I don't see any servos for sale. I am sure there are plenty of used working servos out there in this world, but they aren't in demand because the motors don't break and hardly anybody flies P2Vs anymore. What breaks is the arms holding the servos and camera as shown in the link above.
The fact that you're missing the entire servo assy tells me somebody cannibalized it which is a clue that your AC probably has other problems.
What you could do is buy what is available in the link above and use it without the working motor. It is not a real gimbal anyway and won't make much difference. Then at least you'll know if everything works. And maybe you'll stumble onto a servo some day. They are very simple to install.
The other option is to buy a third party gimbal, but if it was me, I'd first be sure everything worked before I put any more money into it.
https://www.ebay.com/itm/DJI-Pha ... :g:TXQAAOSwq39Zr8uK
Good luck.
