coreynach
Flight distance : 208589 ft
Some will, Some won't... If you really want to know if a particular P2 one works, you have to find a forum or post where a previous user as tried it. The Phantom 3 form factor is slightly changed, it's a bit taller, and it's gear is a bit wider (as others have pointed out). This isn't a problem for P2 cases that were designed with a bit extra depth, and with a less snug area around the landing gear... But also consider the controller. It's design is much changed too... so it may not fit well in a p2 controller slot... There have been some cases where the controller slot was generic enough to fit the new one (but less snug) and there are ones where the controller slot very tightly and specifically fits the p2 controller... if you get that case, it wouldn't work without making your own additional cuts..
So will every P2 case work... No way... Will some of the P2 cases or bags work... Yes, likely many will... some will even fit stuff out of the box (though perhaps slightly less "tightly") and others will require a little modification. That said, it looks like P3's hard shell backpack is out soon... I see one US retailer with it for $149, which is a great price. If you are patient, you could have a perfect, and cost affective solution soon:
DJI Turtle backpack |
