lannes
Flight distance : 4465 ft
nixuspix Posted at 2017-11-12 00:15
The only thing, which is very annoying for me is that i need to reconnect the RC end each time i want to fly. The microUSB connection will not serve forever, being exploited in such a manner
It would last longer if it wasn't the micro AB type port, that DJI have mounted upside down. The male plug is so loose that the tab is definitely going to be damaged over time.Each time you connect the otg cable you have to gingerly easy it in, a lot of people have broken the tabs in these ports.
They should have gone with the normal B type port which the more triangle shape allowing the plug to go in only one way
