Elektrica
Flight distance : 9674836 ft
Elektrica Posted at 2017-11-11 14:42
So, just tested the Cendence and the Patch Antenna (It comes with it and it's mounted by default). I cannot get the I2 to go past a few 100 meters without losing signal. I tried different locations, and different frequencies. It is mounted correctly. It just loses signal mostly around 150mt from my position and around 100 mt. high. I tries to direct it toward the I2, no luck! If anyone is using the Patch Antenna, can you please confirm it is supposed to be a more powerful, longer range antenna? Sigh!
Did some testing, the regular antennas have a good signal, the patch antenna, unplugged has an ok (Just ok) signal, if I plug it to the remote, the signal drops. I wonder if the remote is defective or the antenna is defective. Hard to tell
