randy.sauder
Flight distance : 872572 ft
DJI Thor Posted at 2017-12-2 21:17
Hi Randy, we will analyze the case via your flight record. Frankly speaking, if there is only transmission issue, there might not be the cause for the accident, coz even when there is no transmission, the drone could be under the control of the RC.
But now I am not able to view your data, our engineers will review the data and find the true reason of it. Thank you for your understanding.
Thanks Thor for your quick replies. I’m trying to give all my information/data to DJI so that: a) DJI can support me by replacing my Mavic and b) So others can be helped so it doesn’t happen to anyone else. By ‘data’ do you mean the blackbox data on the mavic? I didn’t recover the Mavic; it’s gone (despite searching it’s gps location and contacting every property owner in the immediate area ) so there is no data to extract (I’m going off my best and good memory of my entire flight). Your last reply has me worried…are you saying that I should expect that DJI will not support my claim because even if the app was faulty I still could have controlled the Mavic using the RC controller only? That would be crazy and the RC/App/Firmware are a system and full operation requires all 3 to cooperate. Although I am experienced and can operate with RC only I noted in one of my posts that the RC wasn’t taking my commands also and I doubted the readings too (and near the end of flight it was reading “Connecting…” and I couldn’t reconnect. I also needed the app as the mavic didn’t appear to be moving back to me under my command. One thing I’ve had happen before, and I suspected this, is that it would not move because the sun’s glare was preventing the vision system from it moving. On my return path was possible direct sunlight. I could not go into the app (I tried!) to disable the vision sensors to free it to move! I’m not absolutely certain this was the case, but I couldn’t rule it out b/c the app was faulty and the app controls the RC as you know (Sport mode did not bypass this, so my assumption was the commands by RC were ineffective). By this time I was in critical battery level territory (and my ability to troubleshoot was over) and hovering at 7m while I ran to it’s location and it wasn’t found (despite a couple witnesses who saw it near my last gps location fix). I suspect it landed just beyond where I physically saw it in dense brush or a tall tree. If the app was functioning correctly I would have at least had an accurate gps data to locate it too; at some point the app crapped out and stopped sending/receiving data including GPS. Since it has been nearly 2 weeks since it was lost and my contacts haven’t reported it recovered, I am going to officially enter my support case now. I am trusting, hoping that DJI will do the right thing with all the info I’ve been providing. Cheers. |
