fans0d323f90
Malaysia
Hi guys. New to the drone and the forum.
Hope you you guys can clear some of my doubts.
I am having some issue with the range. I seem to loose signal and live feed when My drone is approximately 450m from the RC. I’ve been googling around, reading this forum and YouTubing and apparently with the 4.1.17 update it switches from 5.8G to 2.4G automatically when the range is too far for 5.8G. As mentioned, I start losing signal when I’m approximately 450m from the drone. Should I keep pushing it beyond 450m for it to automatically switch to 2.4G to get better range? I tried hovering at approximately 450m thinking it would probably switch to 2.4G, but it lost connection and RTH was immediately initiated.
I’ve not use the previous version of the app and apparently from what I googled and YouTube, you can manually set it to either 2.4G or 5.8G. But with the latest update, I can’t seem to change it manually.
Secondly, since I’m planning on pushing it beyond 500m, was wondering if I would lose visual without OTG? From what I read and understand, OTG only helps when it comes to live feed clarity and latency. Does the 2.4G or 5.8G channel actually affects the latency and the range of the image displayed on my device?
Thanks in advance guys for the clarification.
Glenn |
