Osmo SD Card Problem !!!
2675 3 2017-11-12
Nithin Vijay
India
When i tried to switch on my osmo ( i haven't been using it for past few weeks ) the fan wasnt working and when i connected it with my mobile i wasn't able to get any display.
and the both lights was staying stable !!
my firmware was old and wanted to upgrade it so i unmounted the sd card and tried to copy the latest firmware but it wasnt responding ( the card wasnt recognised by the pc and laptop ) but i used my cell ph as a card reader and copied that latest firmware file to the SD card ( the card which i got with the osmo )
i switched on the  osmo with out the sd card and it was working perfectly
and the firware upgrade wasnt happening...
is it the problem with the SD card or The Card Reading Slot of OSMO ???
Can i insert any other low quality  sd card (not class 10 and all )  to the osmo to check whether it is working ??
Please Help !
Inserting and image of osmo when the card is being inserted
2017-11-12
Solid yellow of the left indicator means SD card Error. I think you can change another SD card to have a try.
But higher speeds are recommended for Micro SD card.
2017-11-13
Bonemaker
This forum is uselessness
You never get any solution to any problems here
2018-7-19
Froppy
Flight distance : 10361 ft
Philippines
It's 2020 and STILL there is no solution in this problem.. I have the same problem.
2020-2-26
