djiuser_K6W99Ar
Mexico
Jenee 2 Posted at 2017-11-13 21:36
Most sensible people would have pulled the throttle down in combination with the CSC method. You can't blame the equipment when the user is in control of it and doesn't understand the basics.
If you are driving along in your car and another car of object is suddenly in front of you, are you going to look for a button to fix everything or are you going to do the basic actions required to stop or avoid the accident.
You need to learn how your drone works, how it is controlled, what to do in emergencies because as soon as you start it, you are in control and are responsible for what happens.
No, that was not the problem, because the drone fell just in front of me, so I catched it very quickly, CSC takes 3 seconds to stop the motors ! (and it tries to move the drone before of that!)
On the car example this is like if we should stop it using a weird movement and also wait 3 seconds instead of just using the break pedal.
Stop the drone should be something really quick and easy, like it is on a car, because is an emergency.
In the done situation stopping the motors should be also automatic, becase is not so hard to detect that.
It took near 2 seconds to catch my drone, but in thos 2 seconds all the propellers and maybe motors where damaged because they were trying to spin on the floor and next to a wall !
I can't understand users against a more robust way to detect crashes and stop the motors automatically, or having a better and faster control to do that manually, why you think that is a bad idea???
