How to view settings video was shot in..
7426 11 2017-11-12
djiuser_GZzJ7vv
This may be a stupid question but Is there a way to view the settings used to shot a particular video. I am shoting in 4k, mov and wanted to check the settings I had set for colour mode, contrast etc.. as i obviously cannot remember.
2017-11-12
Ex Machina
Flight distance : 1806362 ft
Sady, there isn't. But there is a way should DJI see fit to add it to EXIF data -- please submit your feature request via Go 4's Me/DJI Support/Product Suggestion interface -- the more of us who request, the more likely they'll consider adding.
This is what a movie's EXIF data currently provides:
iMac:~ lfrancis$ exiftool /Volumes/3TB/Drone\ stuff/Lorton\ 11.09.2017/DJI_0676.MOV
ExifTool Version Number         : 10.61
File Name                       : DJI_0676.MOV
Directory                       : /Volumes/3TB/Drone stuff/Lorton 11.09.2017
File Size                       : 827 MB
File Modification Date/Time     : 2017:11:09 17:23:22-05:00
File Access Date/Time           : 2017:11:09 22:41:58-05:00
File Inode Change Date/Time     : 2017:11:09 22:41:58-05:00
File Permissions                : rwxrwxrwx
File Type                       : MOV
File Type Extension             : mov
MIME Type                       : video/quicktime
Major Brand                     : Apple QuickTime (.MOV/QT)
Minor Version                   : 2014.2.0
Compatible Brands               : qt
Movie Data Size                 : 866774399
Movie Data Offset               : 40
Movie Header Version            : 0
Create Date                     : 2017:11:09 17:21:16
Modify Date                     : 2017:11:09 17:21:16
Time Scale                      : 30000
Duration                        : 0:01:55
Preferred Rate                  : 1
Preferred Volume                : 100.00%
Preview Time                    : 0 s
Preview Duration                : 0 s
Poster Time                     : 0 s
Selection Time                  : 0 s
Selection Duration              : 0 s
Current Time                    : 0 s
Next Track ID                   : 2
GPS Coordinates (err)           : 38 deg 42' 37.47" N, 77 deg 14' 17.48" W, 17.5 m Above Sea Level
Speed X (err)                   : +0.00
Speed Y (err)                   : +0.00
Speed Z (err)                   : +0.00
Pitch (err)                     : +0.60
Yaw (err)                       : +44.80
Roll (err)                      : -0.80
Camera Pitch (err)              : -17.80
Camera Yaw (err)                : +44.70
Camera Roll (err)               : +0.00
Comment                         : 0.9.143
Category                        : v02.05.5661
Model                           : FC220
Track Header Version            : 0
Track Create Date               : 2017:11:09 17:21:16
Track Modify Date               : 2017:11:09 17:21:16
Track ID                        : 1
Track Duration                  : 0:01:55
Track Layer                     : 0
Track Volume                    : 0.00%
Matrix Structure                : 1 0 0 0 1 0 0 0 1
Image Width                     : 3840
Image Height                    : 2160
Media Header Version            : 0
Media Create Date               : 2017:11:09 17:21:16
Media Modify Date               : 2017:11:09 17:21:16
Media Time Scale                : 30000
Media Duration                  : 0:01:55
Handler Class                   : Media Handler
Handler Type                    : Video Track
Handler Description             : DJI.AVC
Graphics Mode                   : srcCopy
Op Color                        : 0 0 0
Compressor ID                   : avc1
Source Image Width              : 3840
Source Image Height             : 2160
X Resolution                    : 72
Y Resolution                    : 72
Compressor Name                 : Dji AVC encoder
Bit Depth                       : 24
Video Frame Rate                : 29.97
GPS Coordinates                 : 38 deg 42' 37.47" N, 77 deg 14' 17.48" W, 17.5 m Above Sea Level
Speed X                         : +0.00
Speed Y                         : +0.00
Speed Z                         : +0.00
Pitch                           : +0.60
Yaw                             : +44.80
Roll                            : -0.80
Camera Pitch                    : -17.80
Camera Yaw                      : +44.70
Camera Roll                     : +0.00
Avg Bitrate                     : 59.9 Mbps
GPS Altitude                    : 17.5 m
GPS Altitude Ref                : Above Sea Level
GPS Latitude                    : 38 deg 42' 37.47" N
GPS Longitude                   : 77 deg 14' 17.48" W
Image Size                      : 3840x2160
Megapixels                      : 8.3
Rotation                        : 0
GPS Position                    : 38 deg 42' 37.47" N, 77 deg 14' 17.48" W
2017-11-12
DJI Thor
Flight distance : 13602 ft
If you had enabled video captions at that time, Home, GPS, BAROMETER, ISO, Shutter, EV and Fnum will be recorded. If there is a need for displaying other settings, maybe I will try to forward this requirement to the engineers. Thanks for bringing us the attention.
2017-11-12
Montfrooij
Flight distance : 2560453 ft
This is a great suggestion.
I sometimes wonder the same.
Not sure if there are EXIF fields that are available for video files.
We have had this in our pictures for some time now.
2017-11-13
Montfrooij
DJI Thor Posted at 2017-11-12 21:27
Will they be added in the EXIF fields of the video file?
2017-11-13
DJI Thor
Montfrooij Posted at 2017-11-13 00:13
The need has forwarded to our engineers, they will see if it will be possible.
2017-11-15
Montfrooij
DJI Thor Posted at 2017-11-15 01:26
Thanks for that.
2017-11-15
DJI_camera
DJI R&D Squad
Hi djiuser_GZzJ7vv,
Thanks for your suggestion. Now the GPS info and gimbal info would be in the mov file which have been fetched at the start of the movie recording. For the other information, we will talk about it inner and may try to add it to the the MOV later.
2017-12-6
Alexei Merinov
Flight distance : 4796509 ft
Vietnam
DJI_camera Posted at 2017-12-6 16:48
Hi djiuser_GZzJ7vv,
I've got that video caption, but where could I check the meta-data, could you, please, show the screenshort?
2017-12-26
questech
Hi,
If the camera settings (iso - shutter speed - f/stop - etc) were saved in the Video file, then Adobe LightBridge (and other apps) would easily be able to read it.
Most cameras (all that I use other than the one on my Phantom 3 Pro) store that data in the video file, why didn't DJI opt to add this important data?
DJI has been around a while and these aren't 1st gen cameras I don't think...
What can we do to help them see the value in this simple request?
Thanks...  Anthony
2018-2-12
tazzt0ne
Flight distance : 1240184 ft
Switzerland
white balance settings would also be nice in video metadata
2023-1-15
djiuser_zyklide
Hi DJI Thor,
can you provide some feedback from your engineers?
2023-3-19
