Dockater
Flight distance : 139649 ft
C-Mobile Posted at 2017-11-12 12:23
my problem is as follows: DjiGo4 application does not recognize my phantom4 radio remote control, not even with dji assistant 2 but if I turn on the drones the remote control and djigo4 nevertheless cause to fly the p4 as if it were in ATTi mode but it obviously saw flight data including the image.
Hi, C-Mobile,
The above is not helping you much, and you seem to be having a bad day, sorry.
There is not enough information to clearly identify the problem. It sounds like a classic firmware discrepancy or partial update. Have you tried to do updates recently? Have you flown the combination ac and controller combination successfully before? If so what have you done since then?
I suggest you check that the latest software and firmware are up to date for all items, (check the numbers on the units and on the DJI website), the ac, controller, camera, App etc. If all is correct then you need to make a cold start (reboot) of all devices, including your iPhone, iPad or Android phone or tablet.
Good luck, and report back. |
