Inspire 2 unstable hovering
12
11062 67 2017-11-12
DRAGenDROP
Flight distance : 26170253 ft
SkyFilms Posted at 2017-11-13 12:15
Mindy -
Here we are at 80' and as you can see from the leaves, no wind.    Inspire 2 drifting all over the place.
yes, thats what I have to, come on DJI we have jobs to do!
2018-9-30
Alex Dawson
Flight distance : 1787395 ft
Sweden
DRAGenDROP Posted at 2018-9-30 01:31
I'm going to update mine right now. Fly a few times and see if the landing gear works and if its more stable. Living on the edge with DJI
2018-9-30
Alex Dawson
Sweden
Alex Dawson Posted at 2018-9-30 08:20
I did the upgrade and decided to make a short flight in the dark and what it seems like mine workes fine? I tried the landing gear like 5 times and try to fly in a straight line in pretty hard winds and there were no problems. It seems to fly more stable than ever. I was only 5-10 min in the air so I will have to try more tomorrow in daylight.
I run my I2 with the  X7 camera and latest firmware with a regular controller with the latest DjiGo app on an iPad Pro. My drone is from Feb 2018.
I was happy to see the Prores RAW and RAW HQ in the app when I formatted my SSD card
Kind regards // Alex
2018-9-30
Matthew Dobrski
Flight distance : 1831050 ft
Alex Dawson Posted at 2018-9-30 09:34
Alex, to make sure I understand ... You just upgraded Inspire 2 firmware to .0200 version, correct? And - after a brief test flight - you haven't seen any abnormalities? This will support my thesis that only a fraction of Inspires out there can be affected by certain bugs in this version of FW. Or - in contrary - there's nothing wrong with .0200, only particular combination of Go 4 app version/RC firmware/device OS may exhibit some abnormal behaviour.
Please perform more elaborate testing at your convenience and keep us posted.
2018-9-30
DRAGenDROP
DJI Mindy Posted at 2017-11-14 01:25
Hello, the new firmware of Inspire has just been released, would you mind updating to the latest version to have a try?
What is the version number Mindy.
Always be clear please!
sorry
2018-10-3
DRAGenDROP
do you also have the next problem?:
When landing the machine on a little steep suface just a second after the drone haves his feet on the ground it try's to stay level, that's a very dangerous situation, when landing on a big ship, also when landing on a fixed surface that is a little steep, I meen really al little steep or more.
before we had never had this!
Also the camera swings to the left almost 180 degree to the left after the landing.
2018-10-3
Rodger8
Flight distance : 20145135 ft
A known issue right fro the get go. I will say that the latest GO 4 App helps a bit with the Hover.
2018-10-3
adamhw
Any updates on this from DJI - I don't remember it being this bad but have just updated to the latest firmware (27.02.2019), calibrated IMU, Vision Sensors, Compass, new foam filled props and apart from it being a bit quieter it's still wandering like crazy in hover when in gps mode - I compared it to my P4Pro and it's all over the place in comparison.....
2019-2-27
djiuser_1VbYiOTzyTc0
Romania
I get crazy how unstable is the Inspire 2. My Mavic is much more stable. I spent a lot of money to buy the I2 because in advertising they say that is "ROCK Stable" in the air! In the advert they say "for cinematography use". Hard to believe! How can the stability can be fixed? My I2 is useless in this condition.  Any suggestions? Any updates regarding this issue? Thanks guys.
2019-3-9
Romania
I am very frustrated because I see a lot of complains regarding the I2 stability since 2017 in this forum and DJI let its clients in the air without a ferm response! INCREDIBLE! I want an official answer from DJI admin. If there are so many complains regarding stability it means that IS A REAL PROBLEM WHICH NEED TO SOLVED ASAP!!!
2019-3-9
FarmerMac
Flight distance : 1215079 ft
Denmark
djiuser_1VbYiOTzyTc0 Posted at 3-9 22:04
NOW you are unfair!!
You cant expect to both pay a huge stack of  money AND get a
product that works!
Jokes aside... Got the same problem, but have realised that the way
DJI handle this issue might be by annonucing EOL for the I2 and then
launch the I3.
IF we are lucky DJI will launch one more FW update but rest asure that
it will bring up a lot of other issues.
2019-3-10
magli149
Flight distance : 509678 ft
Sweden
I have the exact same problem with my Inspire 2.
Any news on this topic now by mid 2019?
2019-7-23
magli149
Sweden
Looks like this:
Video from the drone:
Unstable hover. Moves slightly but constantly side to side and up / down. Same at low and high altitude. Same in no / low / high wind conditions.
Drone now has about 3 hours of flight time or so (all for troubleshooting basically).
Tried several careful IMU-calibrations (followed by careful compass calibration)... also tried doing calibrations very quickly after power on and after waiting a bit.
Tried with both sets of propellers that came with the drone.
Tried in a few totally different locations to eliminate that this is due to external factors.
Also tries calibrating the controller sticks, gain adjustments and all other far fetched stuff found in forums.
2019-7-25
sincabeza
Flight distance : 2508911 ft
Ukraine
ohshhh...
Im not alone with same problem ...
have anyone tried to turn off the sensors ?
my P4Pro more stable then $8K toy from DJI ...
2019-8-14
GeoffG
Flight distance : 810082 ft
2019-8-14
magli149
Sweden
Nothing new on this?
Seems to me like it is time for DJI to fix this or provide refund or upgrade!
2019-8-18
Revette
This issue just started with our I2, flew fine for months then it just randomly starts?   Saw there was newer firmware, installed it, recalibrated etc and it still persists.   Doesn't inspire confidence in these products
2019-8-21
bachir_photo_ph
Flight distance : 20013228 ft
United Arab Emirates
same here both my old inspire and the new one purchased 3 days ago....
2019-8-21
Mr.Burns.666
Same here,i got one Phantom Standard,one Phantom 4 Pro,one Inspire 1 and they are all much more stable than my new Inspire 2...
It hard to believe that this problem still haven't been fix about 3 years after the release of the Inspire 2
2019-11-8
ToscanaDrone
Flight distance : 13833304 ft
Two inspire 2 in two years and both the same problems!
No stable hovering and constantly moving up and down. Very hard to work!
2019-11-9
AeroMovie
Flight distance : 1539337 ft
The unstable drifting in the air is unfortunately only one problem of our two Inspire 2.
There is also the constant compass calibration. It's funny that Inspire 2 has become so quiet.
I see it coming soon that there will be an Inspire 3 (or similar) and the Inspire 2 will be dropped by DJI.
link: calibrate permanent compass:
https://forum.dji.com/thread-193546-1-1.html
https://forum.dji.com/thread-201099-1-1.html
Link: Inspire 2 unstable hovering
https://forum.dji.com/thread-138920-3-1.html
https://inspirepilots.com/threads/inspire-2-unstable-hover.23199/
2019-11-11
AeroMovie
@DJI Mindy
What's going on DJI Mindy? Don't you want to answer all the questions or don't you want to answer all the problems???
After all these complaints, it's time for the Inspire 2 to hear what DJI has to say.
Has the DJI flagship Inspire 2 hit an iceberg and is now threatening to sink?
2019-11-20
FVP
Not stable and can’t fly on strength line.
2019-11-21
sincabeza
Ukraine
Hello, DJI ?
any FW updates for stabilized hoovering ?
2019-11-24
AeroMovie
Really, no answer from DJI.
Hello DJI Thor, DJI Tony, DJI Mindy?
What's going on?
Views (4.3K) for this post and you don't notice it anymore?
2019-11-28
FVP
Thank you DJI....
2019-11-28
sincabeza
Ukraine
DJI, where is the solution ?
2020-4-26
Rob W
Flight distance : 94390 ft
Sweden
sincabeza Posted at 4-26 23:56
DJI does not care about their professional photo and film drone. It is a year and a half since the latest firmware. It lags behind in functions compared to their small old drones. They promised ProRes RAW for the X5s but now they say they won't do it... I've invested a huge amount in DJI drones, cameras and sensors, but I think I will abandon DJI now.
2020-4-27
12
