Mark The Droner
Flight distance : 2917 ft
Sunny D Posted at 2017-11-15 11:12
Doesn’t RTH hover at the selected height? I didn’t think RTH also does auto-landlords but I always retake control when it gets close so I’ve never found out.
So, how do you cancel RTH if the app doesn’t respond?
Yes, RTH will land once it reaches homepoint.
To cancel RTH, you toggle the S1 switch. The beauty in this is the S1 switch is part of the 5.8 signal so it has nothing to do with 2.4. The OP wasn't clear what he meant when he said he cancelled RTH and I suspect he never toggled the S1. He also wasn't clear when he said he "lost comm." I suspect he had 5.8 the whole time and didn't know it. Common error.
The other thing is that on some of the Androids, once 2.4 is lost, the device will not reconnect to the Phantom automatically. This is only on some Androids. I'm not sure if it's FW version or what. So once you lose the 2.4 wifi, if it doesn't seem to want to come back, you need to go to settings and reconnect with the Phantom (i.e. the controller) manually. It'll say something like "No internet, will not connect automatically." So connect manually. Then when you go back to the app it will be working normally.
I suspect this happened to the OP.
