Failed update 0x20106 firmware V.01.04.0000
2000 18 2017-11-13
djiuser_ijKDgux
Hey guys, since I got my Mavic pro, my drone won't update to the latest firmware V.01.04.0000. Can anybody help me how to solve this issue, please? I tried everything from updating it through DJI GO 4 to my Mac using Assistant 2 V. 1.16. The update stops at 44% and it would fail from there everytime.
All applications are up to date.
Rc is up to date.
Thank you
2017-11-13
djiuser_ijKDgux
2017-11-13
DJI Thor
Flight distance : 13602 ft
Hi, please leave me with your DJI account, I will forward a beta for your solving the issue.
2017-11-13
MR. STEALYOGIRL
DJI Thor Posted at 2017-11-13 19:08
awesome, joaofajardo28@gmail.com
2017-11-13
DJI Thor
Hi, the beta is available to your account now. Please refer to the steps below to upgrade it via the DJI Assistant 2 again.
1. Log into your DJI account.
2. Upgrade the firmware V 01.03.0813.
3. Once it's done, please press the "Record" button on RC and make sure it's recording, then start to upgrade firmware to the latest version, it will be working.
2017-11-14
MR. STEALYOGIRL
DJI Thor Posted at 2017-11-14 01:09
It works! thank you so much! I just have a quick question since i'm new with Mavic pro. Since you bypassed it using beta, it was updating to V. 1.03.0813, then when update was successful, out of nowhere the firmware was at the latest firmware V. 01.04.0000. Does that mean it has all the new update (features) from the official firmware 01.04.0000? Because the [official] firmware 1.04.0000 is still there ready to update, but the AC is at 01.04.0000 already.
2017-11-14
DJI Thor
MR. STEALYOGIRL Posted at 2017-11-14 09:21
Sorry, do you mean that when you finish upgrading to V. 1.03.0813, then the firmware is already showing as v1.4.000? Could you please provide me with the screenshot of the DJI Assistant 2? I'll check.
2017-11-15
Desertruler
Hi, I am in the same situation. While updating  to 01.04.0000, I got failed update 0x20106. Do I need the beta also?
Thanks
My account is: reha@gomuc.com
2017-11-15
k2m2
Philippines
Hi, I'm also having the same problem.
Would be great if I get a response asap
k2m2_01@yahoo.com
2017-11-15
DJI Thor
Desertruler Posted at 2017-11-15 18:54
Thanks
My account is:
Yes, the beta is available to your account now, please refer to my post on 5#. See if it helps.
2017-11-16
DJI Thor
k2m2 Posted at 2017-11-15 22:44
Hi, also, you can access the beta now, please refer to the steps on 5#.
2017-11-16
k2m2
Philippines
DJI Thor Posted at 2017-11-16 05:27
Thanks!
Updated to V. 1.03.0813 successfully. Do I have to update/downgrade the Mavic Remote for beta version too? It was able to update successfully to 1.04.000 before the problem occured
2017-11-16
DJI Thor
k2m2 Posted at 2017-11-16 19:10
Thanks!
Hi, you don't need to update the RC to the beta, and I thought I had just replied you on another post. Please check.
2017-11-21
Gilad3
Flight distance : 45469 ft
Israel
SOLVED!!!!
After trying everythingggggggggggggggggg.........
I Saw this on someone's else post and i can verify this worked for me.
You have to use an IPHONE. I used IPHONE X, the other guy used IPHONE7 PLUS.  (6 will not work)
You just update using the DJI GO 4. (note: on iphone DJI GO and DJI GO4 are different)
whenever the percentage seems stuck, or slowed - PRESS the video shoot button - a lot of clicks untill it wil continue. (it takes time. if its not failing - its working)
this is how you get to 100% and update completes.
if this wont work for the first time, try again!  i succeded on 3rd try.
Enjoy
2018-1-29
Gilad3
Israel
SOLVED!!!!
Enjoy
2018-1-29
fans825b1d05
Flight distance : 200144 ft
Armenia
hi Admin, i have same problem with mavic 1 .. can i get  1.03.0813 ?
2019-5-7
DJI Thor
fans825b1d05 Posted at 5-7 01:22
Hi there, may I know the current firmware version that your drone is running? I'll check if the beta firmware works for you.
2019-5-8
fans825b1d05
Russia
dji mavic pro 1.4.400   .. ill try to update any firmware - sometime flashed , but after reboot Mavic firmware still 1.4.400  , sometime i get error   0x20106  account ba@skymec.ru
2019-5-8
FlyinCameras
Flight distance : 2613205 ft
Account = mkirk467@gmail.com
2019-5-15
