htenbos
Flight distance : 270469 ft
DJI Thor Posted at 2017-11-14 20:24
Please confirm if the app and your mobile device OS are up to date. It is said the connecting issue is resolved and users' feedbacks are positive. The latest app is v4.1.17. If it doesn't help, please try to change the connecting cable, and see if you can control the gimbal by the RC.
Let me know if the issue persists, a screenshot of the app is highly appreciated.
I have uploaded a picture. As you can see the main issue is that the app says 'disconnected'
I am using the latest version of the iOS app (4.1.17), the latest version of iOS (11.1.1) and the latest version of the firmware on the Mavic.
I have also powered on my Mavic and RC first and once those are up and running and connected, I have plugged in the lightning cable in the iPhone 8 Plus. I've also tried different cables. I use the bottom USB port of the RC.
Using a workaround, I have just downloaded 2 earlier versions of the DJI GO 4 app (.14 and .16) onto my iPhone 8+. Unfortunately both versions have the same problem, they also don't connect.
I also use Litchi and also this app won't connect to the drone.
As indicated above, I also have an iPad (Air 2, running 11.0.2) and this iPad has no problem. The moment I plug in the cable, the flight bar turns blue and I am able to connect to the drone.
Before the iPhone 8 plus I was using an iPhone 6, latest software version 11.0.2). This phone was connecting to the drone, but only after powering up drone, RC and starting the app. Once the cable was plugged in, the connection would be made.
Hope this helps and wish DJI can fix this issue asap. I am off on holiday next week and now the only thing I can do is bring my bulky iPad so I can still fly ..... |
