DJI Thor
Flight distance : 13602 ft
Confuso Posted at 2017-11-15 08:38
I took Cycle Paradise's advice and just went out and flew it. All went well until the Mavic disconnected from the controller when it was about 8ft off the ground and about 6ft away from me. Could actually have grabbed it but fortunately i had set RTH and it soared 20ft in the air and landed back on the patio.
However I have now completely lost confidence in it. I'm baffled how I could lose control with no warning a few feet away.
It seems like the drone initiated failsafe RTH.
For the control distance, it sometimes relates to the flight environment, we would suggest that you fly the drone in an open wide area. Check the antennas position of the remote controller. Distance should be greater than height during flight, and please make sure the remote controller’s antennas are positioned parallel to and are pointed towards the aircraft, you can refer to the picture below. Still, use a mobile device with a strong performance. And for the simulator, please make sure that DJI Assistant 2 is the latest version.
