ruggbg
call it whatever you want.......it tells the pilot where they are, where North is and where the drone is RELATIVE to the pilot (assuming the pilot is handling the controller in a normal fashion in from of them.
If you did not have the white triangle you would not know if the drone is to your right, in front of you, to your left, or behind you. You would have to make the ASSUMPTION that the top of the screen was the direction you are facing. In this case you would be right, then this thread would be "Why doesn't DJI show me where I am facing?"
Strictly speaking, it is neither a radar (since it uses GPS and not radio echos)
"Electronics. a device for determining the presence and location of an object by measuring the time for the echo of a radio wave to return from it and the direction from which it returns.
a means or sense of awareness or perception:"
nor ATTITUDE (since it is only showing XY axis = but Z is shown elsewhere)
"Aeronautics. the inclination of the three principal axes of an aircraft relative to the wind, to the ground, etc."
