Yes, up in the top right hand corner of the web page you will see your current avatar inside a small circle. Click on that, select 'Personla Homepage', then s'Settings' and then you should see 'Set My New Avatar'. Browse for a new one.
SunSets Posted at 2017-11-14 17:48
Naaa... thkd GeeBex....... It asks for a name change, NP..... but the Avitar [ used to change pix] box is grayed out always....
Click on the box, and it will sometimes ask if it can run Flash, then two boxes should appear, one titled 'Browse' amd the other 'Take a Photo'. BTW, trhe selection stays greyed out anyway, but it still works.
The avatar change depends on Adobe Flash plugin. It does not show in all browsers. In Firefox there is no indication whatsoever. But when using Safari I got a hint that Flash was needed.
