Labroides
Flight distance : 9991457 ft
djiuser_XhNALOxUxgF5 Posted at 12-15 21:40
Hi DJI Elektra,
I recently had the same Ready to Go (Vision) twice, due to being down inside waterfall jungle depressions. In both ocasions, DJI Mavic PRO 2 wouldn't fly above 6, 7 meters. It would just get stuck on that height.
This is because that's the way your drone is programmed to work.
It's explained on p57 of the manual:
- Height is restricted to 16 ft (5 m) when the GPS signal is weak and Downward Vision System is activated.
- Height is restricted to 98 ft (30 m) when the GPS signal is weak and Downward Vision System is inactivated.
how can one go around the 6, 7 meters heigh limitation to be able to fly the drone in a free mode ??
Deactivate the VPS sensors and you will be able to climb 30 metres higher than the launch point.
BUT .. if you don't have GPS because the drone's skyview is blocked by your location, the drone will not have horizontal position holding ability.
Flying without GPS the drone will have no brakes and won't stop when you take your hands off the sticks.
That can be very risky if there are obstacles close to your drone.
