Remote Controller Support Rig
3517 15 2017-11-15
RichfromHowellN
Flight distance : 508255 ft
The Cendence comes with the Remote Controller Support Rig preinstalled.  I can't find any documentation or videos showing how it is used.  It is supposed to be intended to offset the weight of the Cendence when using it with the Crystalsky by some how attaching the Cendence to the operators waist.  The only reference I see is on the DJI Website stating:
The Cendence Support Rig takes on part of the controller’s weight, making it easier to hold for long periods of time..
But nothing on how it is used. Does anyone have more information/documentation/videos on how Remote Controller Support Rig is supposed to work?
2017-11-15
Well, this is just a small accessory to offset the weight of the Cendence like you said, since the Cendence is too heavy, you can just hold the rig when you don't use it to fly the drone, much like the rig in normal RC. rig.png
2017-11-16
RichfromHowellN
DJI Mindy Posted at 2017-11-16 01:33
Well, this is just a small accessory to offset the weight of the Cendence like you said, since the Cendence is too heavy, you can just hold the rig when you don't use it to fly the drone, much like the rig in normal RC.[view_image]
DJI Mindy .... some how it seems like the Cendence Support Rig was an after thought.  I called up text support and they were not able to give me a good answer either.  It is almost like the put this on for some future use.  They claim it is supposed to offset the weight by resting it on the abdomen.  Sorry but this really does not make much sense to me.
2017-11-16
RichfromHowellN Posted at 2017-11-16 14:10
Hi, Rich, I may fail to explain it clearly.
Since the Cendence is a little bit heavy, users may feel tired when hold it with two hands for a long periods of time.
With this rig, users can hold the Cendence against his abdomen(belly) to reduce the the weight of the Cendence.
2017-11-16
RichfromHowellN
DJI Mindy Posted at 2017-11-16 19:33
@DJI Mindy - so I guess the rig is acting as a spacer between your abdomen and the back of the Cendence.  Otherwise if you are just holding the Cendence against your abdomen, you could do this with out the rig being in place right?
2017-11-16
RichfromHowellN Posted at 2017-11-16 21:37
@DJI Mindy - so I guess the rig is acting as a spacer between your abdomen and the back of the Cendence.  Otherwise if you are just holding the Cendence against your abdomen, you could do this with out the rib being in place right?
Yes, exactly, it will make you more comfortable.
2017-11-17
fansa84fe8a4
Flight distance : 3 ft
Is that piece metal or plastic?
If metal, one could drill and tap a 1/4"-20 hole to use it on a tripod.  That and if the width and bevels were correct for an Arca-Swiss mount, it could lock onto the mating clamp made for that industry standard.
2017-11-24
RichfromHowellN
fansa84fe8a4 Posted at 2017-11-24 11:00
To be honest with you, I'm not quite sure if it is metal or plastic.
2017-11-24
daev2018
Flight distance : 12263747 ft
Metal, but too thin to get enough threads in.
2018-2-23
rfAndy
Flight distance : 396365 ft
daev2018 Posted at 2018-2-23 23:41
Hoodman makes a tripod mount for Cendence - as long as you don't use RTK equipment.
2018-3-12
broadlandboy
Flight distance : 1654222 ft
Thought it was it keep the vents clear
2018-3-12
fans29ae36a7
Flight distance : 21558 ft
Malaysia
I think it kinda does both. You can rest that area against something without blocking the vents.
I made a hook out of flat bar and hook the remote onto it (lazy me)
2018-3-13
RichfromHowellNJ
Take a look at this thread.  Until Secret has come up with a transmitter tray there are sample trays that might make life easier for you in that thread.  Especially the one at the end that shows a modification to the Inspire Secret Tray.
2018-3-13
HedgeTrimmer
Any chance of using a Pre-threaded** expanding rivet?
**Not sure what the proper name is, but I have used them on thin to thick sheet metal.  In case of thin sheet metal, I added a washer to increase thickness for rivet to grab against.
2018-3-15
Killboydotcom
Flight distance : 346883 ft
HedgeTrimmer Posted at 2018-3-15 06:03
Rivet Nut - RivNut - Nutsert
2021-2-1
MedicFL1
Flight distance : 4358570 ft
HOODMAN makes a waist belt that attaches to the Cendence remote controller.
In addition to this item sold by DJI which i still haven't figure out how it works to relieve your arms.
2021-7-11
