fans9553217f
Flight distance : 814751 ft
Guernsey
jreynolds5 Posted at 2017-11-16 03:32
I feel that you are going to need to try multiple flights. I would fly out there and find it with fly 1. Maybe set up a waypoint and fly back. Do not go less than 50% battery. Fly back and see what percentage you have. Load up another battery and fly back out using waypoint and then snap some pics, maybe a video or 2 and when your battery gets to a point that when you fly back you will have about 20% battery left. And because you have it set as a waypoint you can pring it up anytime and fly out there.
Thank you. I was hoping for a comparative chart.
I have decided that non-sport is the best choice at just below max which is on a still day, in excess of 27kph
I am also aware of the variables with battery age etc.
At 27kph, the distance is 2.7km so travel out should be 6 minutes. The same back.
On my last test over land, 24 mins showed as I took off. Time lost because of NFZ matters.
The search area is about 0.5km and a convenient strip of rocks, so one pass should work.
Once found, I will return and try again. This time, and I thought the waypoint idea was a good one, I will overfly and try to video. At least I will get something.
Allowing for variations in battery capacity, i might decide on 6 mins over the site. Total 18mins. I think that is a safe assumption on timing.
I think that has answered my question and thank you all.
