Compass error - cause?
1593 15 2017-8-26
StarFishUK
Flight distance : 54970 ft
I have only had one instance where I received a compass error causing the Spark to go into Atti mode (and leg it away from me like a greased otter). I have spent a lot of time thinking about what might have caused this. I could just have been a random a thing, but at the time I received the rror my neighbour was mowing his lawn with a perol engine lawn mower - about 25 feet away from the Spark.
Could a noisy, clattery, unshielded petrol engine cause compass interference at that range?
2017-8-26
S-e-ven
Flight distance : 5922034 ft
Thailand
I would not say that it can not.
I had compass errors only because I dit put the spark for start on a conrete garden table.
Lifting it 10 cm, the compass was fine again.
This little AC is very sensitive,methinks!
2017-8-26
fans78376957
Too close to a metal object during take off triggers my compass error alert.
2017-8-26
FatherXmas
Flight distance : 4058619 ft
It doesn't take much. I bought a folding card table to get up out of the grass and away from the dogs and I get a compass error on it. The only thing metal in it are the legs.
2017-8-26
Charles Adams
Flight distance : 3821312 ft
I had placed a craft on a cooler, which happened to be filled with some old stereo equipment instead of ice and drinks.  That equipment included some speakers (which have magnets).  That little bit of metal, and just a couple of speakers, and that caused the craft to go haywire.
2017-8-26
Hankmeister
Flight distance : 19465 ft
Normally I'm in Ventura, Ca. and every thing was oky, but went to St Louis for the eclipse and started to get compass error and gps drop out and go atti mode. dji go4 app indicated all was normal but was stiil getting the error on and off. I did compass calibration many times and after three days of this stuff, it started to function normally. Back in Calf things are still normal but my confidence is way low, hopefully I can go higher and farther and get confidence in Spark again.
I am trying to determine how to get the log print out that shows those drop put errors, any help on that?
2017-8-26
Charles Adams
Hankmeister Posted at 2017-8-26 11:26
If I understand the question, I think this is the answer:
2017-8-26
HomePoint
Flight distance : 776007 ft
I have two screws in both my ankles and both hips replaced, my Spark doesn't seem to care
2017-8-26
Hankmeister
Charles Adams Posted at 2017-8-26 11:33
https://youtu.be/ngEHdAlAh9A
still having problems. it is something like "phantom help log viewer"
or
DJI/dji.go.v4/FlightRecord
example...not mine
http://phantomhelp.com/logviewer/SVWEOO40N6P4NDOQ83DI/
2017-8-26
Hankmeister
Hankmeister Posted at 2017-8-26 14:21
or
I found the log viewer
http://www.phantomhelp.com/LogViewer/Upload/
my log showing error.......not much help in finding why the errors
http://www.phantomhelp.com/LogViewer/5JNW1CVI0UGM01F8LR40/
2017-8-26
DJI Susan
I would recommend you to fly away from interference such as buildings, trees, hills, magnetic interference and etc. Calibrating compass might be helpful before take-off.
2017-9-3
DJI Susan
Hankmeister Posted at 2017-8-26 15:07
Please refer the tutorial video of 7# and export the data for analysis, thanks!
2017-9-3
StarFishUK
Yaw Error / ATTI Mode - What am I doing wrong?
I had another switch to ATTI mode today. I have attached the logs - which if nothing else, show that I was nowhere near any electromagnetic interference. If you can't fly safely in a place like this then we have to face facts - you can't fly safely anywhere. Prior to it going into ATTI mode I noticed it was "drifting" to the West (as you can see on the logs) - I've no idea why it was doing this.
I was able to fly safely and brought it in to land, although it regained GPS mode quite quickly anyway. But what am I doing wrong? What steps can I take to stop this happening? Should I calibrate the compas more often? This is now the third time this has happened and I'm getting really nervous to fly at all. I've kind of lost confidence in the device.
http://www.phantomhelp.com/logviewer/SFDGP8L2NQ66OY5T9NUK/
2017-11-15
StarFishUK
DJI Susan Posted at 2017-9-3 22:24
Thanks for this response. But hills, seriously?? How do hills cause interference? I'm starting to wonder if there is anything that doesn't cause interference. Even living in a very rural part of Scotland it is difficult finding anywhere regarded as safe to fly.
I will certainly take you advice about calibrating the compass before take-off.
2017-11-15
DJI Susan
StarFishUK Posted at 2017-11-15 23:52
Ha, you got me... I mean the high mountain that the signal can be easily shielded. I'll attach the video for your reference.
2017-11-21
StarFishUK
DJI Susan Posted at 2017-11-21 02:46
https://www.youtube.com/watch?v=w6Zf90zR378&feature=youtu.be
Now I understand. Thanks Susan.
2017-11-23
