fans9865fdf8
Flight distance : 4455 ft
Help Please!
I have just got my Phantom 3 pro out for the first time since about august. I charged all my batteries & controller. started it up and it was saying "update controller, update the app". so I updated the controller and app (everything went fine). then I tried connected to my P3, the controller would not connect to the P3, so I linked the controller in the App & Hidden button by the SD card slot,(everything went fine) all connected again, then it said "update firmware, update camera" so done that (everything went fine) then put each battery in the phantom incase there was an battery update just to be on the safe side.
Then i took it out for a quick test flight, flew perfectly fine but the picture on my iPad mini kept refreshing all the time, so I landed it turned it off and checked my camera setting in the App, everything seemed ok.
Then I tried to fly again but got an error message when stating the motors.
"ESC Status Error" restart aircraft. if problem persist contact DJI.
I tried a couple of times turning it off and on again but now I just get same error message
and the motors will not start.
These are the versions the App is saying are installed in the "about" Tab
App: Version 3.1.22
Aircraft: Version 1.11.20
Remote Controller: Version 1.9.2
Basic App Fly Safe Database: Version 01.00.01.05
I have reinstalled the firmware again, but still the same problem
It flew absoulutly fine the last time i had it out in august before this update, it has never crashed or had a hard landing, only flown 20 times (1hr 20mins since March 2016)
so i think it could only be a software problem.
Below is a copy of the log that is added to the SD card after upgrade ( I dont really understand what it all means )
The firmware on the SD card is identical to or older than the current firmware on the aircraft.
========== 2017.11.15 15:28:32 =====================
Packet: P3X_FW_V01.11.0020.bin
Result: Abort.
========== 2017.11.15 15:29:55 =====================
Result: Abort.
========== 2014.01.01 00:00:12 remo-con disconnect======
Result: Abort.
========== 2017.11.15 15:41:36 =====================
Result: Abort.
Result: Abort.
Result: Abort.
Upgrading ...
Result: Success.
========== 2014.01.01 00:00:13 remo-con disconnect======
Result: Abort.
Any ideas what I can do to fix this??
