CineView Media
Flight distance : 5365522 ft
Norway
NuminousD Posted at 2017-11-15 18:52
Actually it is moving in the opposite direction of the new motor. Rear-Left motor was replaced, and now it moved Forward-Right, seemingly exactly diagonally. I will check and re-seat the motor and screws and see how it goes. Thank you
Sounds like the motor is slightly off its seat, causing the propeller to be more "efficient" than the others, or an imbalance to the dihedral effect.
In gps mode it wont, cause the controller would mix the three other motors to compensate for the extra efficiency it creates.
Thats what makes most sense to me, after what you describe... |
